Step 1: Visit your local dealership, and purchase the following parts.
6509674AA - Quantity 6 - Screws for Door Woofers
05035254AA - Quantity 2 - Door Woofers
05035253AA - Quantity 1 - 6x9 Sub
05035308A - Quantity 1 - Unity Speaker (This is in addition to the one in the upgrade kit)
82213535 - Quantity 1 - 12 to 18 Speaker Upgrade Kit
05035339AA - Quantity 4 - Buckets for the 6x9 Speakers, This is required as once you remove the cover, it’s exposed to outside)
5035418AC - Quantity 1 - AMP for 2016 Model Year
- Quantity 3 - Bolts for the AMP
Step 2: Unplug the Base Audio Jumper to the right of the steering column, and insert the Jumper into the one labeled Full Audio - THIS IS REQUIRED OR YOU WILL DAMAGE THE RADIO/HEAD UNIT
Step 3: After you have successfully installed the audio, and you have absolutely no audio or feedback (FEEDBACK WILL BE PRESENT IF YOU DO NOT COMPLETE STEP 2) proceed to Step 4.
Step 4: Log into DealerConnect, Under the Service Tab, Inside Warranty Administration - Locate "Vehicle Option Updates"
Step 5: Enter the Vehicle Identification Number or VIN, and Select RCA - Amplifier (Specific to ACR's ONLY, Other vehicles will say RCA - SRT High Performance Audio) and Add it to the Vehicle and Select Save.
Step 6: Using the WiTech Scan Tool, Select Vehicle Preparation, and Select Restore Vehicle Config.
Step 7: Power Cycle the Vehicle, Reconnect with WiTech Scan Tool and Clear Codes. Vehicle Network Topology will show the Radio and AMP as blue
Step 8: Power Off the Vehicle, and induce 2x Sleep Cycles. (Power off the car, close the door, wait 1 minute. Power on the vehicle again, Power off the car, close the door wait 1 minute.)
For additional support and questions feel free to message me directly, if you're not comfortable with installing this yourself, print off this installation guide and take it to your dealer. A dealer will be required to add the sales code and do the vehicle reconfig.
