Results 1 to 15 of 15
    Enthusiast 98intrigue's Avatar
    Clearwater, FL
    Instructions on how to remove OEM shocks
    I haven't seen a how to, so thought I would share my experience on removing the OEM shocks. Keep in mind I have the GTS suspension, so you will not have to worry about removing the remote reservoirs and disconnecting the wiring harness if you have an SRT model. This means you may not need to remove the rear fender liners.
    Rear removal
    1. Start with a T30 torx bit and remove the 8 bolts holding the fender liner around the wheel well
    2. Remove 2 bolts underneath the side sill with the T30 torx bit
    3. Remove 3 10mm bolts adjacent to the bottom of the side sill bolts
    4. Remove 3 more bolts with the T30 torx bit that hold the fender liner to the rear bumper
    5. The last step before removing the fender liner is to remove 1 T30 bolt and 1 10mm bolt
    6. Before pulling out the fender liner, tape off the body to avoid scratching since the fender liners hold a handful of u-clip nuts
    7. Remove the fender liner
    8. Remove the 21mm upper shock bolt and 21mm nut (Unlike the Gen 3/4, I did not have to remove the rubber cover to allow for more room to pull out the shock)
    9. Remove the 18mm lower shock bolt and 21 mm nut
    10. Remove the clip securing the braided line to the remote reservoir
    11. Remove the 8mm nut holding the reservoir to the mounting bracket
    12. Loosen the 14mm nut to allow the mounting bracket to separate in order to pull out the remote reservoir
    13. Pull out the clip that secures the wire that controls the dual mode suspension
    14. Use a small flathead screwdriver to lift the lock on the clip and pull apart
    15. Now you can remove the shock
    Note: On the passenger rear, there's a wiring harness that makes it a PITA to access the top shock bolt nut. I was able to pull the harness away far enough to remove the nut without having to remove the clip that secures the harness.
    Front removal
    1. This process is much easier than the rear since you do not have to remove the fender liner and the remote reservoir is easily accessed
    2. I forgot to take pictures of the upper/lower shock bolts, but it's the same as removing the rear upper/lower shock bolts
    3. Remove the clips securing the remote reservoir and wiring harness that controls the dual mode suspension
    4. Remove the 8mm nut holding the reservoir to the mounting bracket
    5. Pull out the wire that controls the dual mode suspension
    6. Now you can remove the shock
    Ryan - 14 Stryker Green Nth Moto TT/Heads/Cam
    Past - 14 Stryker Green VE Stage II Heads/Cam, '16 ACR-E, '14 Anodized Carbon, '14 TA, Orange '03 Paxton vert w/coupe rear, Black '06 coupe w/SSG accents
    Clearwater, FL
    Installation of my BC coilovers was a breeze...had all 4 shocks mounted in under an hour. I didn't take any pictures of the install because it's simply putting the upper/lower bolts back in. Torque specs are 100 ft. lbs. for all the upper/lower shock bolts.
    Front lowered 1.25" and rear lowered 1". I'll play around with the ride height more in a few weeks when the new wheels arrive. Before and after.
    Enthusiast Rapidrezults's Avatar
    Nov 2014
    Bay Area, CA
    Nice write up and nice new Viper Ryan! That was quick...you just sold your TA! What wheels are you going to put on this bad boy?
    -Chris
    '16 ACR Extreme - White / Black & Red | STAGE II Heads & Cam Package |
    '14 TA - White 19/33 | VE Active Suspension | Arrow PCM | Blah, Blah, Blah(sold)
    Hey brother thanks for doing this detailed install. Your car looks awesome!
    *SOLD*
    2015 SRT Viper - Agency Power Catless Exhaust/Arrow PCM---1999 ACR Viper---2001 Dodge Ram 1500---2011 Jeep Rubicon
    South Miami
    This might be obvious but are you giving up the active suspension? Didnt know you could do that without issues. love my mcs on my srt
    Enthusiast FLATOUT's Avatar
    Montgomery Texas
    Quote Originally Posted by DanH View Post
    His factory dampers are electronic but not "active" like the Tractives. When you go to a non electronic damper it just defaults to race mode. Thanks for the write up Ryan, did you go with the BC's just for the ride hight adjustability?
    ViperExchange Performance Division Lead
    awheeler@viperexchange.com
    2017 GTS-R 004/100
    Previous Vipers
    FIRST AND ONLY NA STOCK DISPLACEMENT VIPER IN THE 9's
    https://www.youtube.com/watch?v=nDsLWMofP4k
    2015 VIPER GT COMPETITION BLUE 9.95@141.2 2016 & 2017 VIPER NATIONALS NA CLASS WINNER
    2014 SRT VIPER TA BLACK #16 1/4 Mile 10.84@134.97
    2008 ACR GTS BLUE/WHITE
    2003 SRT10 COUPE REAR VERT
    viper04's Avatar
    Ryan
    Nice write up! Did not notice you had the new ride.
    2014 GTS Yellow & White ( 1of 1 color scheme) -87 GN -87 Ford Mustang GT 2006 AMG E55
    2003 SRT 10 - 2016 PCP Hellcat Charger 9.58@142.94 (blower only record holder)
    2014 300 SRT 8 ( love this thing)
    Clearwater, FL
    Quote Originally Posted by Rapidrezults View Post
    Thanks, Chris! I had planned on being patient and waiting a couple of months to pickup another Viper, but I don't plan very well...had a deposit on the anodized car the same day I received payment for mine. Going back to my old roots of a 19/20 setup and doing Forgelines.
    Andy answered this one. I was going to go with MCS, but decided to give the BCs a shot due to the price and good reviews I've heard from a couple friends.
    Quote Originally Posted by FLATOUT View Post
    Yes. I have the VE lowering caps, but knew I would want to go lower than what the caps offer. The BCs were the next best solution for me.
    Quote Originally Posted by viper04 View Post
    Ryan
    Thanks! I just picked it up a week ago.
    Clearwater, FL
    Bumping this up in case it can help anyone. I’m using my write up for my green car to get rid of this horrible gap.
    Mountain View, CA
    Quote Originally Posted by 98intrigue View Post
    Nice, hope this helps new or current owners wanting to do the swap themselves. Had my brother help me with my MCS and then again to switch to a stiffer rear spring.
    Btw Ryan, surprised you didnt go with MCS. How much are the BC racing kit?
    Clearwater, FL
    Quote Originally Posted by serpent View Post
    BCs are about half the price. I’ve never had MCS, but have had BC, KW, and Penske. I had BCs with upgraded Swift springs on my carbon car and was happy with them, which is why I went with them again.
    Enthusiast Topplayer's Avatar
    May 2016
    New York
    Thanks for the right up, added it to my bookmarks for future installs!
    p.s. if you decide to sell your oem rims I might be interested!
    Jon
    2013 Viper GTS w/Track Pack --- 2018 Tesla P3D+ --- 2001 S2000 --- 2013 Limited F-150 --- 2013 Polaris Pro-R --- 2009 XR1200 --- 2018 Grom --- 1991 Honda Beat
    Bumping this with a question...
    Anyone have any experience running the BC Coilovers on a TA? Id assume the TA would be similar to this GTS with the electronic dampers?
    Also for the OP, did you run swift springs on both cars? Just wondering if you had any experience with the base 10k/12k rated springs they come with and if you had a preference to either.
    '14 Viper White TA 33/33 - BC Coilovers, HRE 305M's
    '06 SRT-10 NightRunner RC - Lowered 2/4. Full Exhaust, Intake, TB, Tune
    '01 Ford Lightning - Lowered 3/5
    Clearwater, FL
    Quote Originally Posted by GM_500 View Post
    TA has different spring rates and valved shocks compared to the GTS, but any aftermarket solution that works on a Gen V will work for all Gen Vs.
    I’ve done the Swift spring upgrade on both sets of BCs I’ve purchased, so I cannot provide a comparison.
    Appreciate it
