Page 6 of 7 FirstFirst ... 4567 LastLast
Results 126 to 150 of 161
  1. #126
    SSGNRDZ_28's Avatar
    Brownsburg, IN
    Quote Originally Posted by AKTOFL View Post
    Received my order yesterday and installed them today. For those that are on the fence about it, I’d recommend it! All four of the stock black pieces were brittle and cracked through, all the stock nuts had broken off too. Attachment 29060
    It’s such a nice piece of mind to just be able to shut the door and not worry about my window falling down the install is very easy, I’d recommend everyone to try it themselves! That way when the window motor goes out you’ll know how to fix it too the only thing that can really break are the tabs, buy a few and have some piece of mind!! Also, one trick used was to tape the inside part of the boss to the window while getting the outside piece started in the threads. Not enough room in there for me to hold both pieces at once!
    Thanks Doug for a great product that will prevent future headaches!!!
    Ben
    Wow, thanks for posting. These parts really are a weak link. Looks like one was repaired with epoxy? With plastic that brittle it seems a matter of when not if these will break. Thanks to all who brought this to light.
    Doug
  2. #127
    No problem Doug! Thanks for making a fix!! The one that was fixed with epoxy was my doing a month ago...heard it rattling around in pieces when I drove the car. Pulled them out and made a “make shift” solution, then a week later I stumbled on this thread and bought them ASAP �� the others were pulled like that. Had no clue they were about to go.....
  3. #128
    Dec 2016
    Houston, Texas
    top is driver side, bottom is passenger side from my 2013. Two different textures on the plastic manufacture. The "fuzzy" looking passenger ones show signs of cracking while the driver side does not. Drivers side feels slightly heavier an denser.
    Edit: just noticed mine are a different design than AKTOFL's which has a recessed nut, where mine have embedded threads.
    2013 RaceYellow/Black GTS Laguna
    2015 Mustang GT Premium Perf Pack
  4. #129
    Yeah, definitely looks like a different material! Mine feel like they are made of compressed material, like particle board. Crumbed like particle board
  5. #130
    Voice of Reason's Avatar
    Washington, IL
    As an added bonus to the awesome design these parts are NOT covered under the factory extended warranty many of us bought. My warranty just ran out so I’ll be ordering Doug’s replacements soon so I can swap them out myself.
  6. #131
    Quote Originally Posted by Voice of Reason View Post
    Really? The extended bumper-to-bumper should cover any parts like this. That's the idea. Find another dealer. Unless they consider it a "wear item" like brakes.
    2013 Dodge Viper SRT Track Pack Adrenaline Red
    2016 Dodge Ram 1500 Bighorn Quad Cab 5.7L 4x4 Blue Streak Pearl
  7. #132
    Washington, IL
    Quote Originally Posted by swexlin View Post
    My dealer is Roanoke, they took care of me this time (I was like 3 weeks out of warranty) but noted it was not on the list of bumper to bumper extended warranty items. Same as our headlights, if a LED dies in the enclosed housing be prepared to foot the bill. It’s insane the extended warranty doesn’t cover it, but true.
  8. #133
    Crazy. After my R28 passing granted me the extended 10 yr powertrain, I thought about cancelling the 7 yr I purchased. But I didn't, because the needed the NON powertrain coverage. Might be re-thinking that now.
  9. #134
    Glendale, AZ
    Doug-
    Thanks for your efforts on this fix and dedication to making these great cars even better.
    I received my parts, thanks!
    In the past I have just used more archaic means for getting door panels off. What is everyone using for nicer cars such as ours? I see automotive trim puller kits (everything from 4 to 13 piece) for sale on Amazon. Is picking up one of these kits worth it?
    Oh, and someone please do a forum step-by-step tutorial on this please! I know Doug's instructions are good, but I am anal, so the more information the better.
    2004 Silver Gen 3 Vert
    2013 White SRT Viper GTS (Sold)
    1996 Viper GTS (Sold)
  10. #135
    Dec 2016
    Houston, Texas
    i had a tougher than ought to be time disconnecting the speaker thats near the lock/unlock buttons. There is a tab thats under the wrapped foam that you have to push. I used a pick to get at it
    definately invest in some trim removal tools, they are inexpensive. I didnt really use them that much to take the actual door panel off, just the piece of trim near the window up down switches.
    dont think the maximum care warranty is a bumper to bumper, they explicitly list the items that are covered.
  11. #136
    Quote Originally Posted by ForTehNguyen View Post
    I could t figure that connector out and left it connected! Same with the door handle.....I just propped it up and put a towel under it. Still enough room to do the install. As far as pulling tools, I used none, just made sure I was pulling straight out, not to an angle. I broke one of the clips putting the door back on😂😂 when you are reinstalling the window to the bracket keep in mind where the bolts were. You can a adjust the glass a fair bit and can over adjust if you're not careful and cause rubbing on the seal. Simple adjustment to fix it though
  12. #137
    Dec 2016
    Houston, Texas
    for the door handle you can pull the cable off where it snaps into the door, then you turn the end of the cable 90 degrees so the cable head comes out of the door handle
  13. #138
    Thanks for the fix Doug! How can I order? Just posted a thread abt my new 16 srt making horrible noises when the pass side window goes up and down
  14. #139
    SSGNRDZ_28's Avatar
    Brownsburg, IN
    Quote Originally Posted by TT32VGT View Post
    You can pre order on my website but I’ll be out of stock until mid November.
    Doug
  15. #140
    Enthusiast Viper.954's Avatar
    Dania, Florida
    This may have been mentioned already. I just discovered that Doug Shelby Engineering has an upgrade kit to fix the factory parts for $75. When my passenger side broke, my car was out of warranty by one month. The cost of the repair was about $1100 SRT agreed to pay half for me after the car sat at the dealer for three weeks. When I picked it up, my car was covered in leaves and stained. I wish I had known about Doug Shelby Engineering.
    2013 Gen V Base Model
    2016 Ram Rebel 4x4
    God Bless America
  16. #141
    Dec 2016
    Houston, Texas
    im glad i ordered right when these came out, didnt want to wait until Nov for restock. Geez why was it $1100? New glass to get the plastic mounts or did they order a new regulator too
  17. #142
    Thx Doug I'll preorder for both sides for whenever the drivers side goes out.
    Is there anything else you recommend doing while we have the door panel off? Or maybe extra clips or something incase they break?
    I have a 16 srt. Thx
  18. #143
    Hey Doug I bought both sides and sent u an email but haven’t heard back.. just wanted to make sure you received PayPal payment, I know u said mid nov
    Thx
  19. #144
    SSGNRDZ_28's Avatar
    Brownsburg, IN
    Apologies if my email didn’t get through but I did reply on the 24th (maybe in junk?) The aluminum parts will be anodized next week and kits will be shipping the week of the 13th.
    The other points of failure that are less likely are the front clip on the window or the regulator but there’s no way of knowing until you get it opened up. I did not need any extra clips but if you want to have some on hand just in case they are mentioned in this thread above.
    Doug
  20. #145
    SSGNRDZ_28's Avatar
    Brownsburg, IN
    These are now back in stock, if you have ordered already they will ship tomorrow.
    Doug
  21. #146
    Quote Originally Posted by SSGNRDZ_28 View Post
    Doug
    My apologies Doug, my filter snagged it!
    Thanks for the reply! Looking forward to the parts!
  22. #147
    I just had this problem recently on my gen 5 2016. It appears all are destined to fail except for those Vipers sitting in museums or like museum pieces. For reference - My car is a 2016 with about 12 thousand miles on it.
    Doug - THANK YOU SO MUCH for making the replacement parts. I just ordered sets for my two windows.
  23. #148
    Doug, any chance you could make a new tougher window regulator? I know it would probably take a lot of engineering but the Viper OEM part is crap and mostly unavailable. There are close to 30 on national backorder. The FCA parts system says there are 35 (I forget which side) in packaging but it has apparently said this for months and therefore probably is incorrect. The other side has no ETA.
    I just had to replace the left side regulator on my 08 (same part for Gen 3/4/5) and I may have gotten the last one out there from JonB (thanks Jon!). The dealer couldn't get one. Anyone that needs a regulator (either side) now is in for a long wait. In fact I wouldn't be surprised if FCA discontinues the part as they have done with many other Viper parts. If that happens, Vipers may sit undriven for the want of a window regulator. Crazy.
  24. #149
    Quote Originally Posted by ViperGeorge View Post
    Many years ago we were close to an actual solution to this problem.
    If I recall correctly, folks with Plymouth Prowlers were suffering a similar fate when it came to window regulators. Same design, same end result.
    There was someone out there that made a conversion to a totally different type of mechanism - one that got rid of the flexible tubing that breaks. It looked very similar to this type of regulator:
    https://rimmerbros.com/Item--i-CUH00...caAinzEALw_wcB
    They started working on the same thing for Vipers, and at one point even had one installed and working in a Gen 3/4, minus one part: they couldn't get it to work with the smart glass/auto indexing (or whatever you call the function where the window drops when you open the door, and goes back up into the weather seal when you close it) feature. Without insights into how that's implemented in the BCM, the project was dead in the water.
    I'm probably mixing up some details at this point, but I think the pertinent info is mostly accurate.
    In my mind, there are three paths to a "fix":
    1. Someone with engineering expertise, probably in conjunction with Prefix, needs to figure out how to make that other design work. Doug Shelby would be a great candidate for the engineering expertise, but he'd need access to the technical details of how the smart glass works. That's where I think Prefix would come in...otherwise, you'd need to find the engineer(s) that originally designed it.
    2. Someone gets the aftermarket to agree to restart production for at least some period of time regularly to ensure there's enough supply.
    3. Aftermarket repair kit
    #1 is going to require a likely not insignificant investment in time and money. I'm sure someone out there like Doug would be willing to take this on as a labor of love, but that usually doesn't put food on the table. And it'd pretty much have to be a labor of love at this point since making aftermarket Viper parts isn't going to make anyone rich. Low production numbers gives you some exclusivity, but it comes at a price.
    #2 doesn't really fix the problem since the design itself sucks, and I also worry about typical Viper parts price gouging. I vividly remember the days post-Gen 4 production when window regulators were over $1k for each side...that got fixed when the Gen 5 came out and the prices dropped substantially, but now that it's been out of production for 5 years, we're starting to see the same pattern again.
    #3 is available now, but I've seen so many mixed reviews of either DIY kits or companies that provide this service that I don't consider it a true fix. But it's the fix we have at the moment.
    My $0.00.
    High Flow Cats | Gen 5 Intake Man. | UDP | HPT | 3.55s | MCS | DSS Axles | Nth Moto Clutch | 10.86 @ 130.66, 1.68 60' (+1,344 ft DA, w/ 3.55s & Hoosier Drag Radials)
  25. #150
    Ontario
    J TNT's Avatar
    Ontario,MCVO,PA,OH
    Great post Steve , I believe the factory body module does a count of the window motor commutator signals to do the auto glass indexing ....
    Gen 3 Gen 4 Guys also have the upper door trim issue that is even worse , good thing is they are getting reproduced ...
    Charter Member , SS OHIO
