Results 1 to 12 of 12
    SOberman001's Avatar
    May 2016
    NJ
    Power washing soap question
    Friends, I have variable PSI powerwasher with soap dispensing. Do I have to use a specific soap for a powerwasher safe for automotive use or can I dilute my favorite car soap?
    bluesrt's Avatar
    do know, but would think car wash soap would be ok, as the real power wash soap industrial would be more harsh on internals
    ViperSRT's Avatar
    Rochester Hills, MI
    Watch the pressure. It can take the clear coat right off.
    Moderator
    plumcrazy's Avatar
    ALL OVER
    using a bucket is better and be careful of those car wash soaps they tent to be aggressive
    THE IGNORE FEATURE WORKS, TRY IT...
    San Diego
    Quote Originally Posted by SOberman001 View Post
    Your best best is to get a soap gun that attaches to the power washer. It will drop the pressure to a safe level for the paint and it will feed the soap in at the right rate. Any automotive soap will do. FYI soap guns go through soap like crazy, like a cup or more per car.
    Enthusiast Junkman2008's Avatar
    Louisville, KY
    Quote Originally Posted by ViperSRT View Post
    You ain't gonna separate the clear coat from the car without taking the base coat and primer with it.
    "Marines - Making the other guy die for his country for over 200 years."
    Personally I never use a power washer on the Viper, the one time I did I spent so much time cleaning out all the excess water from the engine bay and surrounding areas that I now find it much easier with a couple of buckets of water
    Best of luck
    New York City
    Quote Originally Posted by Fatboy 18 View Post
    Best of luck
    +1.
    The Viper is full of holes and with pressure washer (even mild pressure), water will get everywhere and stay there for weeks. Not worth the hassle if you ask me. As is, when I wash my car (with a garden hose and pouring water down on it), water starts dripping out of the hood even after a few weeks. I also put thick towels under hood vents to avoid pouring water on the engine.
    May 2016
    NJ
    Thanks for all the feedback guys. I have a soft spray nozzle that will not rip the paint off the car. The spray can be touched with your hand with no pain so it won't hurt the paint. I get the point on water going everywhere and maybe staying there but a good jet spray garden hose would do the same since my pressure washer is not paint-pealing strong at the settings I use.
    For the most part, my questions was just about the soap because I use my pressure washer on my dirt bikes and Land Cruiser.
    Appreciate all the feedback! Always great !
    Enthusiast 98intrigue's Avatar
    Clearwater, FL
    Any soap will do. You can always go fancy and get a scented soap of your preference. When you mix the soap with water in the bottle, use warm water - it increases the foam.
    Ryan - Viperless... for now
    Past - '14 Anodized Carbon, '14 TA, Orange '03 Paxton vert w/coupe rear, Black '06 coupe w/SSG accents
    Louisville, KY
    Quote Originally Posted by ek1 View Post
    +1.
    Sounds like you guys could use the Air Force Master Blaster.
    Sep 2016
    Mark
    2017 Viper SRT
    2016 X5M
