Results 1 to 12 of 12
    Removing the front bumper on a 15 GT question
    Gents
    I am going to be putting on some CF splitters this weekend and I want to remove the front bumper. Is there somewhere to get basic instructions to do this so I don't fish around looking for fasteners or damage something related to the airbag sensors (if applicable).
    Any help is appreciated.
    Scott
    Enthusiast 98intrigue's Avatar
    Clearwater, FL
    No need to unplug the battery though
    Ryan - 14 Stryker Green Nth Moto TT/Heads/Cam
    Past - 14 Stryker Green VE Stage II Heads/Cam, '16 ACR-E, '14 Anodized Carbon, '14 TA, Orange '03 Paxton vert w/coupe rear, Black '06 coupe w/SSG accents
    Thanks! That is very helpful!
    Take note, there may be some plastic washers stacked under the bumper cover bolts that are at the front hood lip. Pay attention to which bolts have washers and how many washers are used in each location.
    2009 SSG ACR Hardcore 1 of 1 before it was cool
    2017 SSG ACR-eXtreme 1 of 1 after it was cool
    PkB2014's Avatar
    Quote Originally Posted by ACRucrazy View Post
    They are easy to slide off and get lost as well. Ask me how I know.
    2017 GTS-R Blue GTC - TA 1.0 Group
    2021 Tesla Model 3 Performance, 2022 GMC 2500 HD Denali
    Thank You for posting 98intrigue and ACRucrazy
    Quote Originally Posted by PkB2014 View Post
    If its any help, 0, 2, 3, 3, 2, 0 may be the "standard" washer pattern.
    Quote Originally Posted by A C R View Post
    If you need to remove the bumper on an ACR, the front belly pan is different than that shown in the manual above. There is no belly pan screwed to the bumper. You can remove the bumper by just removing the 10 screws on the top and 3 on the edge of each wheel well, as the bumper has "U" cut in for the splitter cable as apposed to the "O" drilled in the Gen IVs. The V ACR lower portion of the bumper just slides onto the splitter and is held in place, no screws, so bumper removal is possible, however a bit tricky.
    Removing the splitter will make bumper removal "easier" as far as getting the sides of the bumper off around the very stiff wheel liners. However to remove the splitter you have the 4 large torx underneath, 3 extra torx in the wheel well (not the 3 on the outside) Finally to detach the splitter cables removing the airbox/radiator cover makes this easier with 11mm wrench & socket on the cable support bolts through the grill opening and radiator shroud on top. 2 people makes this whole job easier
    ViperPete's Avatar
    Silver Springs FL
    Can a mod move this to the How-To section?
    2021 Dodge Ram 2500 Limited Cummins 4x4 (my daily)
    1969 Mustang Fastback- 1973 Lincoln Mark IV- 1999 Avenger 3.8L - 2005 Mustang GT - 2020 Dodge Charger Hellcat Widebody
    PkB2014's Avatar
    That's what mine was also. Now it's 0,2,2,2,2,0. Anyone know if there is a part number for the shims?
    Enthusiast KB Viper's Avatar
    Jun 2014
    San Diego
    i tried to find the part number on those plastic washers with no luck then just sandwiched a metal wash between the plastic ones and problem solved.
    Gents
    I am going to be installing my TA2 front splitters (OEM) this weekend which is why I was asking about removing the bumper. Does anyone have the drawings on how those attach (Similar to the 'remove the bumper' drawing in this thread above? It is very helpful for the weekend mechanic.
    Thnks
