Page 1 of 2 12 LastLast
Results 1 to 25 of 32
    ACR rear fender liners having issues sourcing need help
    I'm having issues sourcing ACR rear fender liners even with an ACR VIN. They pull up a part number that's the same as my GTS. For you guys that don't know, ACR has different liners for bigger tire clearance. The ACR also has a shaved down rear fender lip and rear bumper to allow for the larger tire.
    The part numbers that we keep getting are 68138276AG and 6813277AG. The dealer put a few calls into SRT but no luck as of yet.
    Help!
    2014 Anodized Carbon Edition GTS #3 of 50
    Previous Snakes
    2006 Coupe Supercharged - 1999 White GTS Supercharged - 1997 B/W GTS
    Call Prefix.
    Jon B as well.
    2013 Dodge Viper SRT Track Pack Adrenaline Red
    2016 Dodge Ram 1500 Bighorn Quad Cab 5.7L 4x4 Blue Streak Pearl
    Minnesota
    Sep 2015
    68284692AD & 68284693AD specific to 2016/2017
    Colorado/Utah/Wyoming/Montana
    I'm confused. The ACR-E takes the same tire size as a non-ACR Viper - 355/30/19. The tire brand is different but the size is the same.
    I may be wrong but given this why would the inner fender liners on an ACR be different. I think they would be the same.
    Quote Originally Posted by ViperGeorge View Post
    I'm sure because of the excessive downforce and adjustable ride height suspension that rear tire needs more real estate when in a lower position.
    Quote Originally Posted by Mnsrt View Post
    You are da man!
    Previous Snakes
    Quote Originally Posted by Anton28 View Post
    You are da man!
    If that is in fact the case then wouldn't they have used the revised liners on ALL Vipers to simply assembly and reduce the number of parts they had to have.
    Central California
    Exhlr8n's Avatar
    Do you know which one is for driver side?
    I don't know man. I'm sure someone here can chime in with more knowledge about this. All I know is that the liners are different.
    As I've mentioned, the rear fenders are "rolled", in this case, shaved down at the top of the wheel well and the portion of the rear bumper that's in the wheel well is also cut down for more wheel clearance.
    These parts are shaved down so far that the ACR is missing the top two or three bolts that hold the fender liner on at the top portion of the wheel well and also the bolt that holds the fender liner to the rear bumper within the wheel well.
    Previous Snakes
    I checked with SRT and yes they did in fact make a change on the ACR due to the Kumhos being slightly bigger than the Pirellis. They changed the way the liner and rear fascia attach. My contact believes the changes were made to ALL Vipers but he's not a 100% positive. Guess it may have depended on when they ran out of the previous parts.
    I'm not sure about "all vipers" every none ACR car I've checked, is like my GTS. Can you share your contacts info? Id love to chat with him as I'm going through with this conversion and would like to know all the exact changes that were made and any parts ill need in the process.
    Previous Snakes
    ClayR's Avatar
    Manhattan, Kansas
    PM me the VIN and I will check with my parts guy. The ACR is different than the others. The fender is trimmed so the inner liner is different. I know because I melted two set of them and ordered new ones.
    Enthusiast darbgnik's Avatar
    Mar 2015
    Alberta Canada
    I've worn holes in the regular fender liners with my car at track height, and stuffing the tires in corners. So I can see the business case for ACR specific liners.
    Brad Williams
    2015 Competition Blue SRT - V/E DSC Suspension - TA1 Aero - StopTech's - SW2's with Corsas, Hummer H1, 70 Dodge Charger, Ducati 999S, BMW R1200GS, etc
    Central California
    Exhlr8n's Avatar
    By my VIN (2016 ACR-E) its showing part# 6813277AG (roughly $100) There is also part# 6813277AG (roughly $220)
    Can anyone confirm the correct part#. I'm wanting to confirm before buying. The ACR has the additional attached cutout area with the 4 screws (inward).
    Hard to believe it would cost less for that one.
    Quote Originally Posted by Exhlr8n View Post
    Part numbers ending with AG will get you none ACR liners. That's the problem I kept running in to even with an ACR vin. These two are correct. 68284692AD & 68284693AD.
    Previous Snakes
    Central California
    Exhlr8n's Avatar
    Thanks Anton.
    Santa Clara, Ca
    Anton, do you know if the front fender liners are different since the ACR is running larger 19” front wheels?
    2015 Viper SRT
    2007 Night Rod Special
    Thanks Anton.
    Anytime!
    Previous Snakes
    Quote Originally Posted by serpent View Post
    Fronts are the same.
    Previous Snakes
    Does anyone have a part number for the plate with an "E" above? Again, the dealer fails me. Why are they having such a hard problem with sourcing ACR parts???? They cant even get me a part number. Nothing shows up in their system.
    Previous Snakes
    steve911's Avatar
    Cottage Grove, WISCONSIN
    The reason why they are having problems is the fact that there aren't any.....
    Even something as simple as a front marker light. 13-17 all the same part number. There are none anywhere.
    Steve A.
    2013 Track Pack, Comp Coupe VCC 062
    2004 SRT10, 2016 Challenger Scat Pack Shaker, 2017 RAM 3500 Dually 4x4
    Central California
    Exhlr8n's Avatar
    Anton,
    Are you asking about the bolt on area with the "E" like shape in it? Mine is plastic.
    Anton,
    Yes, thats it haha Sounds like its plastic lol I've never touched one and for some reason assumed its metal.
    Previous Snakes
  24. #24
    Quote Originally Posted by steve911 View Post
    What I'm having an issue with is locating the actual part number.
    Previous Snakes
  25. #25
    Central California
    Exhlr8n's Avatar
    Do we know which one is driver's side?
    68284692AD or 68284693AD
