Results 1 to 4 of 4
Thread: Driver s Door
    Jul 2018
    New Hampshire
    Driver s Door
    There is a clunking sound when I open my 2014 GTS driver's door about 2/3 open. Passenger side is fine. Any ideas?
    Not sure if the hinges are the same as earlier gen cars? If they are, just in front of the hinge are two sprung steel plates and there is a metal tab on the door that rolls over the top of the sprung steel plates, the plates may require some white grease, it is known for then to fatigue crack too, the outer sprung plate can drop down to the top of the side sill and if you are unaware it can take a chunk out of the bottom front of the door!
    Here's some pics of what Im talking about, (these pics are from my Gen II) as I said you may have a different set up. Hope it helps.
    Jul 2018
    New Hampshire
    Thanks so much, I’ll check this out
    Enthusiast Dr.Ron's Avatar
    Apr 2016
    Quote Originally Posted by Sunliner81 View Post
    I had that too. It sounded like the body panels were rubbing or getting caught. The 1st time to the dealer they greased it but that really didn't do too much. The 2nd time the had a body shop replace the hinge, paint it and rehang the door. Problem solved!
    Ron
    Current:2014 GTS w/ TA 1.0 Aero,18 speaker HK, CF interior accents,SW's,Bone stock 11.44@127.86, Past:2011 Carbon Edition C6Z06, 2009 C6Z06-Bone stock on drag radials-10.75@128.19, 2006 C6Z06-Bone stock-11.242@122.38, 10.87@127 on DR's,2003 C5Z06-Bolt ons 11.214@122.30
