There is a clunking sound when I open my 2014 GTS driver's door about 2/3 open. Passenger side is fine. Any ideas?
Not sure if the hinges are the same as earlier gen cars? If they are, just in front of the hinge are two sprung steel plates and there is a metal tab on the door that rolls over the top of the sprung steel plates, the plates may require some white grease, it is known for then to fatigue crack too, the outer sprung plate can drop down to the top of the side sill and if you are unaware it can take a chunk out of the bottom front of the door!
Here's some pics of what Im talking about, (these pics are from my Gen II) as I said you may have a different set up. Hope it helps.
Thanks so much, I’ll check this out
Current:2014 GTS w/ TA 1.0 Aero,18 speaker HK, CF interior accents,SW's,Bone stock 11.44@127.86, Past:2011 Carbon Edition C6Z06, 2009 C6Z06-Bone stock on drag radials-10.75@128.19, 2006 C6Z06-Bone stock-11.242@122.38, 10.87@127 on DR's,2003 C5Z06-Bolt ons 11.214@122.30
I had something different, the boss kit for my viper unscrewed and the the boss and bolts would rattle in my door. replaced and locktight solved the problem.
My door had a tight spot about 2/3rds open. Just feel alike a slight bind and you can hear a small screech but you can feel more than hear.
2018 RAM 1500 4x4
1999 Camaro SS
Both my doors creaked when opening. Hinges were replaced under warranty. After a few months, the creaking came back. The issue with the lithium grease is that you cant spray the back sides of the hinges without taking the door off. Which I really don't want to do.
2013 Viper GTS Blue (no stripes!) with Sepia interior- only 4 made! WannaGOfast 1/2 MILE BEST OF 157.89 mph @ 600WHP
2005 SRT10 Ram- lowered, T56 conversion, B&B longtubes, many other upgrades (my daily)
1969 Mustang Fastback- 1973 Lincoln Mark IV- 1999 Avenger 3.8L - 2005 Mustang GT - 2020 Dodge Charger Hellcat Widebody
