Results 1 to 22 of 22
    Sep 2017
    NJ
    Broken AP Ti Exhaust Fix n Picture Heavy
    So, short recap: AP Titanium exhaust broke at the catalytic converter, both sides. Driver's side broke first, melted/destroyed heat shield on that side only.
    So I hacked the catalyic converter's off... For reference they're 3.1lbs
    After a lot of research, I found the exact brand titanium tubing used to make this exhaust, and used the appropriate same brand welding rod to TIG a straight section in place of the cat:
    Then I cut the tube in half. Really, the proper way to fix this is with a flex pipe inbetween the two halves, which I may still do. But for now I wanted to get the car back on the road. The cut section leaves a ~1mm gap between the two halves. Using a SS exhaust clamp, I can ensure there is a bit of wiggle room allowed for alignment and minor flexing.
    I wrapped the hottest portion of the exhaust and added a bit of fireplace ceramic batting for extra protection. I was going to use the batting on the entire muffler, but I decided that having some airflow past the muffler's outter shell was better than plugging the entire area with the batting.
    Regarding the melted driver's side heat shield. I sourced the OEM replacement heat shield, the OEM rivets, and the OEM adhesive (thanks to some help from this forum!)
    Done.
    Your friendly neighborhood certified driver coach.
    White TA #7
    ApexObsessed.com
    Apr 2017
    Miami
    I hope I'm wrong but it's more than likely going to crack at your welds again
    Sep 2017
    NJ
    Quote Originally Posted by kriskyk View Post
    I wouldn't be surprised if it did, but then i'll install a flex pipe. No biggie
    White TA #7
    ApexObsessed.com
    New England
    38D's Avatar
    Bolton, MA
    Unfortunately I think you, are right. The blue/brown heat affected zone color indicates that the weld wasn’t shielded well enough.
    '16 Stryker Purple ACR Extreme
    '06 Porsche Cayman S (SpecCayman)
    '92 Porsche 964 Cup
    Voice of Reason's Avatar
    Washington, IL
    I thought wrapping the cats promotes premature failure because the heat gets too concentrated?
    Sep 2017
    NJ
    ^no cats anymore
    If it breaks again, NBD, I can fix with proper flex section next time. It's super easy to work on these things. For now, I'm gonna drive it and enjoy what little good weather we have left up here
    White TA #7
    ApexObsessed.com
    Quote Originally Posted by pMak26 View Post
    Done.
    Great Lift !! Who Makes this one
    Jack B's Avatar
    NE Ohio
    Let us know how it holds up, good luck.
    Self tuned HPT 10.85@130 mph (DA=+1000)
    [B]Arrow Heads & Cam - best run is coming
    (Sold) 1997 Red/White -10.9/129 MPH
    Great post! Next time though, just go ahead and type out the extra letters Agency Power so everyone knows what you are talking about! LOL
    What was the brand of titanium tubing?
    2013 9.0 liter track car, 2016 ACR, 96 GTS, 01 RT/10, 03 SRT/10, '16 Megacab, '05 Ford GT
    Sep 2017
    NJ
    Quote Originally Posted by Copperhead06 View Post
    It's the Quick Jacks 5000 model. -should probably edit your post so it doesn't have all those pictures again. Makes it extra hard for people on mobile to have to scroll thru them all again.
    Quote Originally Posted by Arizona Vipers View Post
    It's Ticon Industries Grade 1 (CP1 or ERTi-1).
    White TA #7
    ApexObsessed.com
    Regional Technical Director
    Ontario
    Garron's Avatar
    Newmarket, Ontario
    Something to consider, most exhaust manufacturers delete the front hanger on the exhaust. Just keep the one near the exhaust tip. The engine moves, you can’t have a solidly mounted front pipe.
    Enthusiast dewilmoth's Avatar
    Mar 2016
    Flower Mound, TX
    Is there a Ti flex tube available, and is that what you’ll use if/when you need to change it?
    Alabama/Tennessee
    99RT10's Avatar
    Armpit of the US
    It cracked up near the header, correct? If so, primarily because the engine will twist(torque) while the supporting rod is trying to hold it in place(front of catback). Remove that front supporting rod and it won't break again. There is too much torque under acceleration for something not to give. The catback will stay in place with out that rod if everything else is tight.
    Sep 2017
    NJ
    I haven't sourced a Ti flex pipe yet. If I need to replace, I was going to band clamp a SS 3" flex pipe to the Ti tubes.
    I haven't heard about not using the front hanger completely. I'm not sure I'm willing to risk something else breaking and having the 400* pipe drop onto the very expensive side sill and roasting that. I haven't looked at other systems, is that what they do - delete using the front hanger?
    White TA #7
    ApexObsessed.com
    SilverACR's Avatar
    Jan 2017
    Iowa
    Quote Originally Posted by 38D View Post
    Needed to purge weld the pipe. The pictures show that the pipe was not purged with shield gas exposing the weld to oxygen from the inside. It may hold up, but the next time the pipe should be purged.
    I used to do a lot of walking the cup on stainless food grade tubing earlier in my career.
    2010 ACR absolutely stock... well... kind of
    Enthusiast donk_316's Avatar
    Deadmonton, Albertastan, Canada
    titanium exhaust sounds like a cool idea and all that jazz, but some places have stopped building exhaust, pipes and headers out of titanium due to it just not holding up.
    Quote Originally Posted by Vipes View Post
    Thanks Donk! I was able to confirm this with the FCA and what you said above is 100% correct.
    SilverACR's Avatar
    Jan 2017
    Iowa
    From looking all over the web I’m able to take a guess on keeping the front hanger vs ditching it. If you have the flex pipes between the motor and the front most hanger then use the hanger. If you have headers/ non flex pipe adapter to manifold then don’t use the front hanger. From what I was able to see regarding the titanium AP exhaust systems is that they use no flex pipe and both hangers. I assume this was an oversight on their part and probably doesn’t come up much due to a lot of these vipers not getting driven enough or just not a significant amount of vipers running this exhaust.
    Titanium is a great material and really should hold up just as good as stainless. I think a stainless system would run into the same issues if there isn’t room to flex.
    Whom ever noticed the front hanger no flex joint is likely on to the root cause. Good catch.
    edit: garron and 99RT10
    Jack B's Avatar
    NE Ohio
    Quote Originally Posted by SilverACR View Post
    The stainless exhausts are .062 thick, just a guess, that is two or three times the wall thickness of the titanium tubing. There are literally hundreds, if not, a few thousand stainless exhaust systems on our Vipers (all gen's) with few, if any issues.
    ViperPete's Avatar
    Apr 2015
    Silver Springs FL
    I always thought it a dumb thing to no have flex sections in an exhaust system. I have been considering cutting a piece of my Belangers out and welding in a flex section.
    Glad you fixed it though.
    2013 Viper GTS Blue (no stripes!) with Sepia interior- only 4 made! WannaGOfast 1/2 MILE BEST OF 157.89 mph @ 600WHP
    2005 SRT10 Ram- lowered, T56 conversion, B&B longtubes, many other upgrades (my daily)
    1969 Mustang Fastback- 1973 Lincoln Mark IV- 1999 Avenger 3.8L - 2016 Maxima SR- 2005 Mustang GT
    Jack B's Avatar
    NE Ohio
    Quote Originally Posted by ViperPete View Post
    Question - have you ever heard of a Belanger or ARH system failing?
    SilverACR's Avatar
    Jan 2017
    Iowa
    Quote Originally Posted by Jack B View Post
    All I have seen have the front hanger ditched which would help in regards to flexing and failure. I have heard of collector gaskets failing prematurely which could be either a bad installment or flexing.
    In any case poor engineering or installation will lead to undesirable results with any material. Obviously the AP titanium exhaust in this thread met an early demise which falls into one of the aforementioned reasons.
    Jack B's Avatar
    NE Ohio
    The Belanger's are machined flanges which supposedly do not require a gasket, that is wishful thinking, as you said, they tend to leak. I do not think it is flexing just an install issue, I have had the best luck with Belanger's when using a soft copper gasket at the collector flanges, which means two per side.
