Results 1 to 23 of 23
    New Gen II owner questions
    Recently purchased a 97 GTS coupe and have a few questions.
    1. Is there a simple way to connect a battery disconnect under the hood since the battery is not readily accessible?
    2. I would like to clean engine and under hood area using a hose and soft brush with soap. Anyone ever done this? Cover electronics? Disconnect battery?
    Thx
    1. No.
    2. I would not use a hose. Some do...and, some pay the penalty...such as misfires, shorted connectors, modules. If you do proceed with your hose plan, be sure to use your air compressor to blow the water out from around the spark plugs.
    Hopefully, the show and shine guys will offer more suggestions for you.
    daveg's Avatar
    Mass
    When I use the tender I just take the RED + cap off the PDU post and connect + there and connect the - on the negative post under the PDU near the rocker, Don't disconnect the nut on the + PDU post because you could have the stud rotate and ruin your harness. I then access the tender cable from within the gill with the hood closed. I disconnect everything when going for a ride.
    I wish to kill power to the car when not in use. Any suggestions? Battery not accessible.
    daveg's Avatar
    Mass
    Quote Originally Posted by GregM View Post
    Why?
    So you are not bothered about PCM Memory, radio losing its programs or alarm?
    Do you not have power access to run a Battery Tender?
    There are some who have installed a cutoff switch in the rear at the battery. I really have not paid attention regarding how they accessed said switch.
    My own solution is to use battery tenders...noting solar is an option in some locations.
    Switching to a GOOD AGM battery has solved most of these issues for me.
    Thankfully, Gen III, IV, and V cars come with a built in solution.
    daveg's Avatar
    Mass
    I can leave my 96 GTS all winter without the battery going dead (without a tender on it) so if the reason for disconnecting is the battery going dead after time, its my opinion there is a draw somewhere. Its usually one of the switches (ie door, hood or back hatch) that leaves the interior door switch lights etc on...
    Battery drainage aside I always kill power to my older collector cars. Ever see a shorted harness go up in smoke? Scary. 21 year old harness is not that old and most of my cars much older. Those harness are dry and brittle. Doesn’t seam like it’s possible on these...
    As for the under hood cleaning I didn’t plan on using a power washer. Just mist the water and blow dry with compressed air.
    And, I know of a switch or two that caused the fire...once while the driver was in the middle of the intersection. There are risks and benefits to all solutions !! To each their own.
    At mopar buying parts
    I've been working on these cars for near 20 years now and have never heard of an electrical fire or major chassis wiring meltdown esp while sitting. I also clean the snot out of my engine and engine compartment using foaming degreaser in the can and high pressure hot water. Never had one single problem because of that.
    Red. Because I didn't have to settle for blue.
    Regional Treasurer
    Black Adder's Avatar
    Nor Cal
    The "lighter" socket on the dash is permentantly live on mine so i just plug the battery tender in there.
    Tony Bates
    2001 GTS-ACR Red/Silver Stripes : 2014 Porsche Cayman S : 2010 Supercharged Jeep Rubicon Unlimited : 1974 MGB V8 : 1931 Model A Street Rod
    ACRSNK's Avatar
    Quote Originally Posted by Black Adder View Post
    This
    1992 RT/10 - The One & Only FIRST
    2002 ACR - Graphite / Silver Stripe 1 of 22
    2017 GTS-R - The Most Amazing and The Last
    Dec 2017
    Congrats on the Gen 2 ... My first one was an '01 GTS. Loved that car! I have a battery cut-off switch on my Gen 3. I also have a CTEK tender that connects in the rear. Mine sits for long periods of time, and I prefer to not have power running through the car. I was away on a trip early 2018, and came home to brake lights on. The switch at the pedal was faulty, and was hot as hell when I reached up to disconnect / remove it. The brake lights were obviously hot, even made that section of the car cover toasty. Would it happen again? Likely not, but it happened once. Enjoy your Viper!
    Last edited by Gen3CoupeTX; 01-03-2019 at 08:04 AM. Reason: 2018, not 2017. Forgot we were in a new year!
    Quote Originally Posted by daveg View Post
    Why?
    So battery does not discharge....or risk electrical short when away from home for extended periods??
    I've killed 4 batteries in my corvettes in the past (usually because of my own dumb mistakes) by leaving doors open, 3rd-party electronics (sound systems, alarms, dashcams....all of which require "hot" leads to maintain configurations), failed on-board control electronics, etc.
    .....however, with the Viper I have adopted using a battery tender at all times. Battery disconnects add more problems than they prevent/solve.
    I'm debating on putting a cut off switch in the hatch. Easy Peasy.
    Does the stud on drivers side frame rail, where you charge or boost battery from, attach directly to the negative side of battery?
    No. The cable from the negative post of the battery is connected to a different stud on the frame rail at the rear of the car.
    Good to know.. do u disconnect battery? Bag any electronics?
    Quote Originally Posted by Gen3CoupeTX View Post
    Exactly. How/where did u install switch? I don’t want to alter a wiring harness...
    Enthusiast Matt Dillon's Avatar
    Dec 2014
    Deep South
    I've always just went out & started it up & let it run for a few minutes when it's winter here but winter here doesn't last very long in La. Are you not in a position to do this? JW
    13' SRT Viper, 00' RT/10 Viper, 18' LS500 Lexus, 15' RCF Lexus, 08' H2 Hummer
    You could use a switch like this https://www.amazon.com/Cllena-Batter.../dp/B01IQRMGFA
    You could mount it in the boot or trunk of the car, I would disconnect the NEGITAVE on the battery and then get a new longer cable, you may have to drill a hole in the trunk near the LHS Amplifier.
    You would need to remove the LHS Rear wheel and fender liner to gain access.
    I would not disconnect the Positive terminal.
    Dec 2017
    GregM, I installed my cut-off switch in the trunk area, inside the car ... Wired directly to battery nearby. I didn't need access to it from outside. Just don't lock your keys in the car when shutting the rear, since cutting off the battery locks the doors.
