Results 1 to 22 of 22
    Going with 3 91 gears on the 9 liter
    My 2013 is at Prefix now getting new pistons, Jesel rockers and solid cam and a new 7200RPM redline.
    With the new higher redline, I can run 3.91's and still have slightly higher shift points, the best of both worlds.
    (Stock shiftpoints) 3.55's, 27.4" tires, 6400rpm redline 1st 65mph, 2nd 93mph, 3rd 123mph, 4th 147mph, 5th 191mph
    (New shiftpoints) 3.91's 28" tires 7200rpm redline 1st 68mph, 2nd 97mph, 3rd 129mph, 4th 153mph, 5th 199mph
    So not including the extra power the motor will make, I'll be putting 10.14% more torque to the wheels from idle to redline and will have to shift less often.
    This, combined with the extra 50-60hp/tq this is going to drastically help my lap times
    My experience is that that's too much gear for a built Gen 5. It seems to not give the motor enough time to pull the gear and traction is limited.
    Are you gonna run an OS Giken or Wavetrac LSD?
    Just my 2 cents, your opinion may differ.
    Enthusiast stradman's Avatar
    Nov 2016
    London UK
    Quote Originally Posted by Dan Cragin View Post
    Yeah I got a Wavetrac on my 9.0 and initial impressions are defo positive
    Enthusiast Redx's Avatar
    Edmonton
    whats the difference with this new cam?
    With 7200RPM and taller tire I think it's gonna work. Plus I run Michelin slicks, right now with 730whp I can floor the throttle in 2nd gear and put 100% of the power down.
    I'm going with the stock diff, what would be the advantages to the other two you mentioned? (OS Giken or Wavetrac LSD)
    3:91 sure sounds like a TYPO to me................You've been seeing #39 on the car so long you brain-melded it?
    I would be thinking 3:19, not 3:91 ! I agree w/ Dan Cragin 100%.
    NOTE: 3:21 avail, stronger carrier bolts and a HD 24-spline yoke. Beefy.
    Virginia Beach
    I think it sounds like one hell of a ride! Do it.
    Did you read my whole post? I'm running 28" tall tires, redlining at 7200 RPM and running a big solid cam.
    Here's what your suggested 3.21's would do with my setup lol-
    1st gear 87mph
    2nd gear 119mph
    3rd gear 157mph
    4th gear 187mph
    5th gear 243mph
    As I stated, my car currently puts down 100% throttle all thru 2nd gear, why would I want less power to the wheels? I've researched this for my car, for my needs on the tracks I run and 3.91's will be best. The car will still put down 100% throttle in 2nd ( I never use 1st gear road racing) and my shift speeds are STILL higher than stock.
    Pappy's Avatar
    Las Vegas/Phoenix
    Here's what 3.21's would do with my setup lol-
    1st gear 87mph
    2nd gear 119mph
    3rd gear 157mph
    4th gear 187mph
    5th gear 243mph
    As long as you can still put the power to the ground it will damn sure help with the drag races with GT2s/GT3s on the short straights at the tracks you run! With the 3:21s you would mostly be a 3rd gear car. I went with 3:73s - guess we'll see how it works out.
    Pappy
    sharmut's Avatar
    Feb 2014
    While the link doesn't answer your question, does provide VE's perspective into the stock diff.
    https://www.youtube.com/watch?v=LRXVRjDu9aY
    Quote Originally Posted by Pappy View Post
    Pappy
    Yeah it should still put the power down. I can even put the power down now in the top half of 1st with the slicks, but I never use 1st. Right now with the stock gears GT3's beat me up to about 70 and that's with the 9 liter. You've seen it first hand with Jason's I'm sure. The 28" tires made a huge difference in my gearing.
    Pappy
    Your 3.73's with your much shorter tire- 26.8" are going to be effectively almost identical to my 3.91 with 28". Not sure what gears are in your tranny though. Your motor is going to be a monster revver so that's good.
    NE Ohio
    Do the 28" tires fit without rubbing or did you modify the wheel wells. Just an opinion, but, it looks perfect. As far as the traction, with slicks on, my 9L grips well except in first, but, i have the 2.66 1st gear. Even the toyo's grip well in 2nd when the road surface is warmed up
    No mods needed for street use, but my car is very low and on tracks with big elevation changes I have hit my drivers side back body panel and pushed it out a bit. Another guy on here running the same tire did the same thing, I cant remember who. Agreed, this car can put the power down very well with slicks on it, especially the ACR's with the big wing. I'd say I could put down 1000whp in 2nd gear with no problem.
    Enthusiast dewilmoth's Avatar
    Flower Mound, TX
    It’s incredible how much grip these cars have, in the rear especially. I’m very interested in hearing your thoughts of the 3.91s.
    Are you still on the stock crank and rod length at 7200RPM?
    str5010's Avatar
    Oct 2015
    Saw your car at Prefix yesterday, really looking forward to seeing how the upgrade turns out!
    -2008 Venom Red ACR Hardcore
    Quote Originally Posted by dewilmoth View Post
    It's the Prefix 9 liter crank and rods
    Flower Mound, TX
    Gotcha, thanks. Was thinking that was only bigger pistons, forgot it includes a crank and rods.
    str5010's Avatar
    Oct 2015
    Prefix also pointed out there were changes to the oiling system with the 9.0. It's a fantastic package.
    Quote Originally Posted by str5010 View Post
    What is the changes in the oiling system ? A dry sump you mean
    Viper TA - Arrow Stage II Heads and Cam, Bad Boyzz Garage Shorty Headers, Corsa Exhaust, DSE heat shield, DSE vented catch cans
    str5010's Avatar
    Oct 2015
    Quote Originally Posted by GTSilver View Post
    No it's still wet sump in the standard package but it sounds as though they have moved from cross drilled to straight shot oiling in the crank.
    My car already had a Dailey dry sump setup installed by CalvoMotorsports.com
