Results 1 to 11 of 11
    Enthusiast ky13's Avatar
    Nov 2018
    Harpers Ferry, WV
    Hood Pin Location
    I'm trying to determine the best location for hood pins on a Gen 3/4 Viper. I recently installed a carbon fiber Gen 4 hood on my Gen 3 and am planning on removing the factory bracketry in favor of pins. I was leaning towards angled brackets off of the frame (near where the rubber hood stoppers are located), since the Viper doesn't utilize an upper rad support like many vehicles. Pics of setups are appreciated.
    2004 SRT10 Convertible
    kritchie@redhat.com
    Nov 2018
    Harpers Ferry, WV
    To clarify, I'm just going to use pins in the front (AreoCatch). I'll still utilize the factory mounts/struts in the rear.
    The following is a pic of what I'm talking about; there is an existing hole in the frame. I would just use an angled bracket:
    kritchie@redhat.com
    LATAMUD's Avatar
    Tampa / Kuwait
    Look at where that lines up with the hood, you'll have to cut into the scooped air plenum. There's more cutting involved into that new hood. I've only ever see hood pins on Vipers that are full racecar, lift off hoods. I think they would throw off the sleek aerodynamic look with pins.
    Nov 2018
    Harpers Ferry, WV
    I'm not going to modify the scooped air plenum. I would locate the pins far enough to the sides. Also, the aerocatch pins sit flat (see pic below), so no change in looks. It's a CF hood, so a dremel will cut through like butter. The following depicts what I'm planning:
    kritchie@redhat.com
    Enthusiast Fatman2006's Avatar
    Jan 2018
    AZ, CA, VA
    Does anyone know if you have to use different strut supports on carbon fiber hoods?
    06 Srt10 Coupe, 16 Kia Sportage
    V10 Time
    Nov 2018
    Harpers Ferry, WV
    Quote Originally Posted by Fatman2006 View Post
    You can swap them out if you'd like, but it's not a requirement. The factory struts are working fine with my CF hood (that is 11 lbs lighter than its factory counterpart).
    kritchie@redhat.com
    Jan 2018
    AZ, CA, VA
    Quote Originally Posted by ky13 View Post
    Awesome thanks.
    V10 Time
    If you have any pics of what you did, I'd appreciate it. I'm wanting to do this also. What brand carbon fiber hood did you purchase?
    Nov 2018
    Harpers Ferry, WV
    Quote Originally Posted by Smoke View Post
    Haven't had time to tackle this project. I have the Carbon Creations Gen 4 hood.
    kritchie@redhat.com
    ACR-ISH's Avatar
    Apr 2019
    Northern CA
    Hey Ky.... Are you doing it for the "look"? If the latch works the hood should latch fine and it's an unnecessary step, but if you're doing it cosmetically I totally get it. You can try to run the base THROUGH the rubber adjuster so the closing point is also the adjustment point so the hood sits 100% flush. Finite details!
    2014 SRT - Full APR Aero - BC Racing Coil Overs - Forgeline GA3R-6 - and the list goes on...
    Gen3 White "Mamba" #184 of 200
    @acr_ish on IG
    Nov 2018
    Harpers Ferry, WV
    Quote Originally Posted by ACR-ISH View Post
    I would completely remove the factory latch/ancillary components. I was considering going that route, but the rubber adjuster is pretty close to the edge of the hood; the aerocatch latches, while low profile, have a large footprint.
    kritchie@redhat.com
