Results 1 to 18 of 18
    Martyb's Avatar
    BC coilovers installed
    Put them on earlier this week, finally got the stance I was looking for. Handling much improved over stock(had 2 leaky shocks).
    Sourced from RSI, had the best price and service was outstanding.
    98 GTS
    70 LS6 Chevelle
    2014 Ftype V8S
    Definitely looks slammed. Even a bit lower than I run with aggressive track alignment & setup. As low as you have it, you really should find out if it will survive the real world around you. If so, then you will DEFINITELY need to have the front and rear bump steer curves adjusted by someone competent. There are folks in the PHX vicinity that can point you in the right direction.
    Martyb's Avatar
    Car is going to Eddie Martin next week for alignment. Going to get his opinion on the height as well. Pretty flat here in AZ, I don’t anticipate a problem, but will watch closely
    98 GTS
    70 LS6 Chevelle
    2014 Ftype V8S
    Looks like you're at about the same height as my daily. The front lip scrapes everywhere, but hasn't broken over 30k miles, and the car high centers at steep break overs and tall speed bumps. For the most part, take aggressive angles at low speed and its good. However, there are will be some driveways that will make life hell; there is a mark on the top of my bumper from a steep driveway and I just passed on going to look at a new house because the Viper couldn't enter the driveway. Overall, being this low is worth it, the car looks amazing.
    The worst part are bumps on the highway that unload the suspension and then fully compress it (think of a whoop in dirt biking) and the laying frame on the highway.
    Here's my side sill from two years ago:
    Looks awesome Marty!!!
    Martyb's Avatar
    Quote Originally Posted by white out View Post
    I am sitting at 26 1/4 at the rear render lip and 25 3/4 at the front lip. Have put about 50 miles so far and no scrapes. I hope I don’t experience the highway scrape!
    Quote Originally Posted by 99RT10 View Post
    98 GTS
    70 LS6 Chevelle
    2014 Ftype V8S
    Martyb's Avatar
    Thanks Mike!
    98 GTS
    70 LS6 Chevelle
    2014 Ftype V8S
    Curious, what silver/gray car is behind the Viper in the second pic?
    Enthusiast ky13's Avatar
    Nov 2018
    Harpers Ferry, WV
    Quote Originally Posted by C5Longhorn View Post
    Looks like an F Type Jaguar.
    2004 SRT10 Convertible
    kritchie@redhat.com
    Martyb's Avatar
    Correct, Ftype V8S. Quicker than the GTS, but not as good looking or fun!
    98 GTS
    70 LS6 Chevelle
    2014 Ftype V8S
    Quote Originally Posted by Martyb View Post
    Thanks, very nice
    Jan 2019
    How difficult was the install? How long did it take?
    Martyb's Avatar
    Quote Originally Posted by M5toViper View Post
    Super easy, took an hour and a half. Played another hour getting the ride height I wanted, it ok a few tries.
    98 GTS
    70 LS6 Chevelle
    2014 Ftype V8S
    ACR-ISH's Avatar
    Northern CA
    Gen 2 with a great stance and CCWs.... SOLD!!! Beautiful car, Marty!
    Northern CA VOA Operations Director ****** 2014 SRT Viper - Full APR Aero - BC Racing Coil Overs - Forgeline GA3R-6 - and the list goes on...
    @acr_ish and @fivehundrednorth (dot com) on IG
    ACR-ISH's Avatar
    Northern CA
    Dont forget to check your valve settings... mine were not equal... roll them all the the way hard (CW) and then go CCW to your desired setting. 10 out from full hard was perfect for me on my Gen 3, 15 out from full hard was perfect for the new owner of my Gen 3! Everyone wins!
    Just installed mine as well, straight forward process.
    Martyb's Avatar
    Quote Originally Posted by ACR-ISH View Post
    I set them all at 15 clicks, right in the middle. Night and day from the stock set up.
    98 GTS
    70 LS6 Chevelle
    2014 Ftype V8S
    Martyb's Avatar
    Thank you sir! Still have yet to find a rear end on a car that I like better than a gen 2 GTS. Still remember the first time one passed me back in the day
    98 GTS
    70 LS6 Chevelle
    2014 Ftype V8S
