Results 1 to 25 of 30
    Question Effects of running equal diameter front and rear tires
    I've searched and not been able to determine for sure the issue with running equal front and rear tire diameters. On the previous generations there was no stability control to worry about but the car would develop a serious and arguably dangerous rear brake bias. Does anyone have first hand experience running equal or near equal diameters (within 0.5")? Does the computer freak out?
    This will 100% cause issues. The rear tires are much taller than the front, you've got to keep it that way. A little change in height is ok, but not several inches.
    Here's the stock heights:
    Base cars
    295-30-18 25"
    355-30-19 27.4"
    ACR
    295-25-19 24.8"
    355-30-19 27.4"
    We are talking 2.5" LOL.
    2013 track car, 2016 ACR, 1996 GTS, 2001 RT/10, 2003 SRT/10
    Base cars
    295-30-18 25"
    355-30-19 27.4"
    ACR
    295-25-19 24.8"
    355-30-19 27.4"
    Thanks for the reply,
    I am aware of the OEM diameter delta. You sound very sure. What issues will this cause? Do you have first hand experience?
    Vipes's Avatar
    Orlando, FL
    Subscribed.
    I've heard of some having issues with the computer for stability and abs while others never having an issue.
    No first hand experience yet but I plan on trying out R888R either 295/30/19 or 305/30/19 which are 26" or 26.3". Rear would be 345/30/19 at 27.2" tall.
    Black Viper TA #15
    Yes it will cause issues, bucking, jerking, throttle surge, all kind of weird things.
    ACR-ISH's Avatar
    Northern CA
    Quote Originally Posted by Scot@Prefix View Post
    Sounds like a no-go!
    2014 SRT Viper - Full APR Aero - BC Racing Coil Overs - Forgeline GA3R-6 - and the list goes on... NorCal VOA Ops Director @acr_ish / @fivehundrednorth on IG
    Thanks. To confirm, you experienced these things? Which tire sizes were you running? This was with the Stability Control turned off or with it on?
    Quote Originally Posted by Sprockett88 View Post
    Thanks. To confirm, you experienced these things? Which tire sizes were you running? This was with the Stability Control turned off or with it on? Thanks
    Possible answers:
    "Are we sure we are talking about Gen V non-base model ?"
    "YES I DID A DUMB THING"
    or
    "NO EXPERIENCE MAKING THIS MISTAKE"
    1ststrike's Avatar
    WIsconsin
    I tried to run 295-30-19's on the front of my ACR-E. It caused it to go into a limp mode as soon as I got into second gear. The only way I could run this size tire was to put it into full off mode for traction and stability. It would take a couple of laps for the computer to get happy with this. The anti lock braking system would still act like you were at anti lock braking even though you were hardly braking. Scary when coming up to a turn and it won't slow down. Talked with a lot of other ACR-E owners and they could run the 30-19's with out this issue but any bigger and they didn't work. (Limp mode)
    Was trying to run slicks without buying new rims. Ended up getting some 18" forge lines. Specially made to fit over the calipers.
    San Jose, CA
    Any suggestions for 19" tires. The 295/30 PS4S tires are 26", rubs alot.
    Thinking of going down to a 285 width which makes the tire height 25.8". Need to look up what 275 will do, but 275 and 345, front and rear, is that too much of a difference?
    Pappy's Avatar
    Las Vegas/Phoenix
    2016 ACR-E - I tried 335/30 front and 345/35 rear Hoosier A7s on 18 inch Finspeed wheels. With all traction modes on, it went into limp mode in the first corner after going on track. It cleared down the straight and I came in. The next attempt was in track mode. One okay warm-up lap, then in the first hard, high-speed sweeper it went to limp mode (idle) and would not clear until I shut the motor off and restarted. Maybe if I had driven a few laps it would have "learned", but I wasn't in the mood - too hot and too much traffic. I am going to try again when the weather cools down a little. Several others have run the same tires and after a little time, the computer seems to accept the condition. We'll see.
    Pappy
    One of our customers, experienced this on a gen 5 GTS, I dont remember the size off the top of my head.
    Thought he had an engine issue lol
    Ran the sizes by Arizona Viper and he confirmed the sizes were too far off for the computer to think right lol
    2016ACR's Avatar
    Jan 2017
    Fredericksburg, TX
    On my 2016 ACR (non E) w/ceramic brakes I've run:
    Front - Forgeline GTD1 19x11.0 + 30 with Toyo R888 295/30-19
    Rear - Forgeline GTD1 19x13.0 + 62 with Toyo R888 345/30-19
    I've had no issues with all "help" turned on at COTA. Maybe I'm not running as hard as the rest.
    2016 ACR Gunmetal Pearl
    Pappy's Avatar
    Las Vegas/Phoenix
    Scot - actually these were a set of tires Arizona Viper ran a couple of laps on at COTA in his ACR. He didn't have trouble with them, but I think I recall him saying he had a little trouble when he first started running that size, but it cleared up. I will go to a test-and-tune track day and run a few more laps to see if it gets better.
    Pappy
    May 2018
    Blair, NE
    My experience on the TA is they must be at least 1” difference. This setup works with Toyo RR’s, but had issues with R7’s. Both 295/30/19 and 345/30/19. Online sizes are 26.1 and 26.8 for r7’s. 26 and 27.2 for RR’s
    2014 Viper T/A #11
    Both traction and ABS determine wheel slip based on preset parameters loaded into the system. These parameters are based on OEM tire sizes. If you change tire sizes too much the ABS and traction systems believe an axle is slipping relative to the other because one axle is turning too fast based on OEM tire sizes. This can cause the traction control system to operate when it shouldn't and it can cause ABS to operate improperly.
    So let's assume you change rear tire height to be smaller, maybe similar to fronts. Because the diameter is smaller the tire must turn faster to go the same MPH. The traction control system looks at the speeds of both axles and says "the rear axle must be slipping because it is turning faster than the front at this MPH." It then intervenes by activating traction control on rear axle. Similar to what happens if you light up the rears with the throttle. The rears start turning faster than would be indicated based on front axle speed. Ditto with ABS, the system will assume that because one axle is spinning faster than it should the system thinks that one axle is slipping relative to the other under braking and it then activates the ABS.
    Quote Originally Posted by Pappy View Post
    Pappy
    The customer i am referring to was not Arizona Viper. It was a different customer
    Vipes's Avatar
    Orlando, FL
    Quote Originally Posted by Ogme042 View Post
    Ah, I think you may have cracked the code. Could explain why some have issues and others do not. I will go with 295/30/19 instead of 305 based on that with the Toyos. Any rubbing issues up front? Nice TA by the way!
    Black Viper TA #15
    Bryan Savage's Avatar
    Podunksburg, PA
    Based only on doing the math from the sizes of tires and not with a tape measure (and assuming the widths are exact to an infinite number of significant figures...)...
    OEM Front: 295/30-18 = 24.9685 inches tall.
    OEM Rear: 355/30-19 = 27.38583 inches tall.
    I've been running the following sizes on my '14 with no problems aside from the occasional ABS/ESP wiggle for the first couple miles after swapping between different sets of wheels:
    Front: 305/25-20 = 26.00394 inches tall.
    Rear: 345/25-20 = 26.79134 inches tall.
    That's less than an inch difference front to rear, so... inconclusive.
    TA 37/93. 60,442 miles.
    IG: @platinumgrille
    • There is no slash in "TA".
    • Every thread you start is useless without photos.
    • Always post photos when asking questions, and learn to orient them correctly.
    • Do not start a thread that only contains a link to another site. Copy the article and tell us what's up.
    • Use the search function before starting a thread.
    • Joining the forums just to get help and then never coming back is low class. Join and stay!
    Sounds like the best course of action is to stick with the stock recommended sizes and avoid computer headaches. With the Gen5 cars handling so well, I'm not certain if there would be any noticeable traction gain by changing. Maybe someone who has done so will comment based upon their experience.
    Blake
    2016 1 of 1 Viper GTC Prefix 9.0 Stroker Stage 2 Arrow
    dirtyboot's Avatar
    Jan 2017
    Pappy
    I wonder why you're having issues - I know I'm not the only one running 315/30-18 & 345/30-19 [25.44"//27.15"] without issue; your difference is still closer to stock [25.44"//27.51"], unless they made computer changes in later years or acr specific I don't think the calculations would change for it with regards to abs/traction intervention.
    When seconds count - lose a finger; it's extra weight! Who needs 10 anyway?
    I
    I
    Pappy's Avatar
    Las Vegas/Phoenix
    Quote Originally Posted by dirtyboot View Post
    Actually, the 335/30X18 A7s (front) are 25.6 inches and the 345/35X18 (rear) are 26.8 inches. I think that is in the range of what the computer can "learn" after a few laps. It has worked for others. The Hoozier A7 345/30X19 is also 26.8 inches, so no help. As far as rationale for switching tires, there are 2 reasons. The A7s are faster, and I'm not fond of going through front Kumhos in a single track weekend (6-8 sessions). I personally am not looking for aesthetics, and most of the good track tire selection is in the 18" size. If you are not looking for real track performance I can see sticking with the stock sizes/tires.
    Pappy
    Enthusiast BlueAdder's Avatar
    Aug 2016
    NorCal
    If you have the same diameters, hence the same height front and rear, you're eliminating the rake completely which is really bad and the car would handle like crap.
    2018 Challenger T/A 392. 2016 Viper ACR-E Competition Blue
    2005 Lotus Elise (Track Car). 2004 RAM 1500 Rumble Bee
    Quick update for what it's worth. I tested a pair of 315/30R18 rear tires with the OEM 295/30 up front. Diameter difference of 1/2" or less. This was so far just on the street and as soon as I got up to 20mph the traction control light began to flash and it cut power. 10 seconds later the light stopped flashing and everything was fine. I drove for about 3-4 miles at various speeds and acceleration and everything appeared normal. Definitely not conclusive for a track experience. Also, it's a little cold up here to be testing braking but I did hop on the brakes a couple times and really hauled it down fast...something definitely felt weird but it was near or at freezing temps so who knows. The ABS didn't noticeably kick in. ABS aside, I assume the brake bias is severely changed to the rear.
