Results 26 to 32 of 32
Thread: Airjax
    FrankBarba's Avatar
    300# here on Miss Keystone
    1996 Nextel CupCar FS
    2003 Comp Coupe FS
    Quote Originally Posted by ACR Steve View Post
    11 pounds vs jacking the car with conventional jack ????? no brainier it wont effect your performance and think of it on the plus side more time to relax
    I have them in my Cup car and its the best invention known to racing when it comes to fast service at the track. Tip ALWAYS have safety collars on
    Lots of ways to loose some of the 11 lbs fast if its that much of a concern
    No 22lbs is the lightest set I can find including hardware etc. 11 lbs total I'd do it, but 22 is too much for me for now. I've won/lost several events by 1-3 hundredths of a second before which indeed 22 lbs would have changed those outcomes. I'll keep jacking up for now hehe.
    2013 track car, 2016 ACR, 1996 GTS, 2001 RT/10, 2003 SRT/10
    jwalk's Avatar
    May 2014
    The Airjax must be larger bore because it only took 215# of pressure to lift my ACR. I have to add up how much weight this added . I am also adding trans and diff cooler but adding tillet driverside race seat so I will get some lbs back.
    Quote Originally Posted by Arizona Vipers View Post
    Shit actually I didn't add in the brackets to support them, I was thinking they were welded directly to frame. So around 30 lbs would be the mimimum weight and that's the very expensive systems to get the jack weight down that low
    Apr 2017
    Miami
    What's the max air pressure on the airjax?
    Maybe just run 2 of them, do you really need all 4 wheels in the air?
    Quote Originally Posted by kriskyk View Post
    Yeah I do for tire warmers. I only use three jacks though. One on one side, two on the others. I use the smallest 1500lb alumimum harbor freight jacks, pretty light and small, easy to store. Takes maybe 2-3 minutes to get the car up. Takes much longer to get the warmers on and set up though, but what else do you do between sessions? hehe.
    who.. impressive setup AZ. how does the GT compare to the SRT?
