Results 1 to 21 of 21
    Georgia
    Ninjakris's Avatar
    Bonaire, GA
    Klearz side marker light install guide and review
    I finally received my Klearz side marker lights after a couple month wait. Ordered directly from their website. Even though they were on back order initially, they had good customer support when I had questions. I went with clear lens and white housing. I also opted for LED bulbs (amber in front and red in rear). From what I can tell, they use OEM Dodge parts (probably why they costs what they do), separate the lens and housing, paint per order and re-glue the two pieces.
    Quality: 8/10. Just being picky, but I could see quite a bit of glue residue. This is probably because I did white against clear. It wouldn't be as visible on darker colors.
    Fitment: 8/10. This is nothing against Klearz, its the lens' in general. They fit like OEM which is a 8/10 to begin with. The front amber LED's look nice and I'm a little worried the rear red will look pink at night, but I haven't had a chance to see it at night yet, so I will update this thread if that's the case.
    Difficulty level: 4/10. This isn't the hardest thing in the world to do, but you will scrape up your hands and I recommend having a 6 pack on ice.
    Tools needed:
    -Flat head screwdriver
    -10mm socket and wrench
    -3/4" socket for removing wheels
    -T 27 Torq bit
    Optional:
    -Drill with adapters for sockets
    -Breaker bar & Torque wrench for wheels
    As for the install, there is no instructions so it was a little bit of a learning curve. It took me around 2.5 hours from beginning to end. If I were to do it again, I could get it done in a little over a hour I think... I hope this helps others out there who are going to take this project on.
    Rear removal: Get the rear in the air and remove the wheel. Remove all the T 27 Torq screws in the wheel liner. Most are obvious, but don't forget there are a couple on the under side of the car by the exhaust, and a few on the under side of the bumper. There is also a T 27 in the middle of the liner along with a 10mm screw. Once all that is removed, the liner should be free and can be moved around. At this point, push/pull/slide the liner towards the car a couple inches to reveal the inside of the lens. As for removing the lens, I found it easier to pull the light bulb section from lens and hold it out of the way. Last thing holding the lens in place is two 10mm bolts (if you want to call it that). They are by far the biggest pain in the ass thing with the whole install. My fat fingers and a wrench or socket had a hard time getting it off. Once they are off, use a flat head screwdriver on the inside center section of the lens to push in the push-clip in so the lens can slide out.
    Rear install: Now is the time to install the new bulbs if you ordered them. FYI-factory bulbs are clear. Pull out the bulb from the assembly you moved to the side earlier. Install the LED in its place. ***Turn on your parking lights to make sure the light turns on.*** LED's are directional. If it doesn't light up, rotate it 180 degrees, try again. After you good with lights, put the lens in the whole, screw in the two 10mm bolts from the disassembly, push light bulb assembly into lens hole, button up all torq bolts and put your wheel back on.
    The images above are all parts of the light bulb assembly. I took it apart because I didn't know what was doing. You don't need to do that, just pull out the OEM bulb and install LED in its place.
    Front: I struggled with this, but I know how to do it now First, remove the front wheels. Second, remove all torq bolts in the front section of the wheel liner that are attached to the bumper. Third, remove all the remaining torq bolts on the top and bottom of the front bumper. This seems like a lot of work, but trust me, you will appreciate not tearing up your hands with the limited space by only removing some of these. Once the bumper is loose, you can slide it forward enough to get in there and remove/replace lens and bulbs. Same as the rear in that regard. ***When removing the bolts on the top of the bumper, be observant of the spacers between the bumper and bumper support. Some had none, others had 3. Part of a hand made car I guess.***
    Here is before and after:
    14' White w/black stripes SRT. 18 speaker stereo, sidewinder II's, Sabelt leather
    (Sold) 06' VCA coupe 14/50. Paxton supercharged, Gen IV hood, Corsa exhaust, ACR wing.
    (Sold) 03' Black convertible.
    Lynchburg, VA
    Awesome write up with great detail!
    I've never liked the markers either, but that's a lot of work for swapping them out. Probably not too bad if you paired it with another upgrade going on and the car was already up with liners loose etc...
    2015 Stryker Orange GT Viper (soon to be for sale) --- 2014 Ford Roush Raptor --- 2009 Porsche Carrera 4S
    Bryan Savage's Avatar
    Nowheresville, PA
    Great write up. Thanks for the info!
    TA 37/93. 55,897 miles.
    IG: @platinumgrille
    • There is no slash in "TA".
    • Use the "New Posts" button to make sure you never miss a post.
    • Always post photos when asking questions, and learn to orient them correctly.
    • Every thread you start is useless without photos.
    Tysons Corner, VA
    I guess the important question - was it worth the time and money?
    2015 Silver SRT (Sold)
    2013 White SRT + Corsa Exhaust (Sold)
    Nine Ball's Avatar
    Houston, TX
    Good write-up. I had my painter do these for my previous Camaro, might try something similar on the Viper. Just wanted to reduce the big color area, had them painted body color with minor slits.
    www.DV8motoring.com
    2014 Viper TA white #10/33 | 2013 Viper - 10.97 @ 127 mph - First 10 second Gen 5 (sold)
    2006 Viper - 9.48 @ 154 mph - 209 mph 1 mile - 187 mph 1/2-mile
    Georgia
    Ninjakris's Avatar
    Bonaire, GA
    Is it worth it? if you are already doing a deep clean on the car and will have it in the air with the wheels off, then probably. Otherwise, it's a lot of work for a cosmetic change. I like how it looks on my white car, but for the price, any other color car should look into something like tony did on his Camaro. In fact,
    if I would have really thought about it, I should have done the same thing when I had my engine covers painted white.
    I really didn't like the orange and red in the side of white car. Seemed to throw off the flow of the body and paint.
    Also, I checked the light output last night and the rear doesn't look pink at all. It's a very nice clear red.
    Georgia
    Ninjakris's Avatar
    Bonaire, GA
    Daytime shot. It does really clean up the sides
    Moderator
    plumcrazy's Avatar
    ALL OVER
    looks perfect
    THE IGNORE FEATURE WORKS, TRY IT...
    ViperPete's Avatar
    Apr 2015
    Silver Springs FL
    I wonder how they would look on my blue car. They would basically just be blue housings with a clear outside? I dunno if that would look good on mine. I cant picture it.
    I applaud your initiative though! looks good on yours!
    2013 Viper GTS Blue (no stripes!) with Sepia interior- only 4 made! WannaGOfast 1/2 MILE BEST OF 157.89 mph @ 600WHP
    2005 SRT10 Ram- lowered, T56 conversion, B&B longtubes, many other upgrades (my daily)
    1969 Mustang Fastback- 1973 Lincoln Mark IV- 1999 Avenger 3.8L - 2005 Mustang GT
    FSTENUF's Avatar
    PAST RED LINE
    Attachment 11969
    I did mine with tint when i rapped the car.
    BELANGER HEADERS/HI-FL0W CATS / EXHAUST/TRACTIVE SUSPENSION AND ARROW TUNE
    Ohio
    BadAndy's Avatar
    Close to Columbus OH-IO
    I'm probably going to be a Gen5 owner here soon. White. I know these things are going to bug me. Appears they're not offered anymore anywhere. Anyone know any different? I'd settle for being all red, just not orange. Tks, Andy
    Enthusiast stradman's Avatar
    these guys still do it....I got mine from them.
    http://www.clearcorners.com/products/dodge/viper5/
    Georgia
    Ninjakris's Avatar
    Bonaire, GA
    Quote Originally Posted by BadAndy View Post
    Man, I forgot all about this thread. I still have the clear fronts, but the rears started having problems so I swapped back in the OEM lenses. As for aftermarket solutions, check out the side marker lights for fiat 500's. I'm 99% sure I read they are the same as the gen V viper. Something like this:
    https://www.ebay.com/i/123178497224?...26pg%3D2386202
    Enthusiast Matt Dillon's Avatar
    Dec 2014
    Dodge City
    Quote Originally Posted by stradman View Post
    Lol, $500 for a Pair, Really! SMDH
    13' SRT Viper, 00' RT/10 Viper, 18' LS500 Lexus, 15' RCF Lexus, 08' H2 Hummer
    Ohio
    BadAndy's Avatar
    Thanks guys! That FIAT option looks like a monetary winner. Guess I'll try that first when it comes time. Appreciate it - Andy
    Looks Great, especially the white on white, BUT really only 1 six pack in 2.5 hours!!! maybe I really do have a drinking problem. great write up
    I ordered the fiat ones and I have been very happy with them, I've had them on for a year and a half maybe 15,000 miles.
    Quote Originally Posted by IHOP View Post
    The fiat are front only? Can you use the front for the rear?
    Quote Originally Posted by Ronin47 View Post
    Nope they work for both
    ACR-ISH's Avatar
    Apr 2019
    Northern CA
    Quote Originally Posted by Matt Dillon View Post
    That's insanity. I'll just smoke mine... or maybe they can send me some clear lenses... I'm pretty good with krazy glue.
    If you guys wanna do a run on smoked lenses this winter I'll do all four for $50/set if you ship them to me. Lemme know!
    2014 SRT - Full APR Aero - BC Racing Coil Overs - Forgeline GA3R-6 - and the list goes on...
    Gen3 White "Mamba" #184 of 200
    @acr_ish on IG
    Quote Originally Posted by ACR-ISH View Post
    Do you paint it or use tint?
