Results 1 to 15 of 15
    Upgrade Brake pads
    Hello everyone, I am looking to replace my brake pads with something a little better. I recently tracked my car and was experiencing some brake fade after a couple of hot laps. What do you guys recommend for brake pads?
    NON ACR Car
    Enthusiast TA Two Oh's Avatar
    Nov 2014
    Alberta, Canada
    How fresh is your fluid? Pads can definitely overheat, but it's far more common to experience fade from brake fluid that's exceeded its temperature limit. It only takes a teeny bit of contamination for temp survivability to plummet.
    2015 TA 2.0 Venom Black. 2001 Sapphire Blue Roadster SOLD, 1994 Viper Black Roadster SOLD
    Jun 2018
    Mandeville, LA
    Fluid should be the first thing to change out. Motul 600 or Castrol SRF are the most commonly used high performance brake fluid to use.
    Georgia
    BSLSK's Avatar
    Quote Originally Posted by CajunViper09 View Post
    I'm switching to Motul DOT 5.1 soon. Does anyone have experience with it?
    2014 GTS
    San Jose, CA
    I did a track day in my 15, solid rotor stock pad car, swapped the fluid to motul 600. Got brake fade in the middle of the 2nd session at laguna seca.
    Definitely need a combo of fluids and pads. Planning to get two piece rotors too.
    Quote Originally Posted by Marc_ View Post
    NON ACR Car
    I use Raybestos R45s in front and R43s in rear. They are rotor friendly, quiet (at least on my car), lower dust, and they come on at ambient temp. They also last a long time.
    G5 assumed due forum....
    George cites a good option.
    Over 25 yrs we have used and offer a mix of PFC, Mintex, Brakeman, Brembo, Raybestos.
    Driver skill matters.
    R-Compound tires generate a LOT more brake heat !
    The track could matter.
    Fluid is a big factor.
    SS lines help...
    Optional Track-Pack Aero rotors help a lot.... saves 24 lbs rotating mass, and vent as much as 60% more air !!! On sale at $1595 ALL four, avail for G3-4-5
    JonB@PartsRack.com
    Bruce H.'s Avatar
    Apr 2014
    Quote Originally Posted by BSLSK View Post
    I tried this as a first fluid upgrade but it was only slightly better than stock on my car. Castrol React SRF was next.... and last fluid I'll ever use.
    I found this to be an excellent combo as well. Will be trying Hawk D7 front and D6 rear next which I expect to be very similar.
    2014 SRT Black TA, stock with driver mod. Last of the 159 built. Thanks to Ralph and Team Viper for an incredible Viper!
    2019 Porsche 991.2 Turbo S,
    Everything that has been said above here but don't forget about adding some 3" reinforced silicone ducting hose from the front brake duct (I even did my rears), routed through the control arm, & land behind the caliper. May be the cheapest and most significant upgrade, but combined with better pads and Motul, if you still cook the brakes you are over driving the car.
    FSTENUF's Avatar
    PAST RED LINE
    Motul 660 fluid with ST43's and ST45's pads are the best set up for tracking and they do very well on the street.
    BELANGER HEADERS/HI-FL0W CATS / EXHAUST/TRACTIVE SUSPENSION AND ARROW TUNE
    On street tires it was your fluid for sure, not your rotors or pads. Castrol SRF is the best by far, but has been on a national shortage for months now. Any of the other racing brands will work as well
    Enthusiast USAFPILOT's Avatar
    Jul 2018
    SS lines help...
    JonB@PartsRack.com
    off topic...but are those rotors available for a 2016 Hellcat?
    Thanks everyone, tires are r888r all around. The fluid was changed before the track. However I didn't use anything special, I will look for some SRF if not, then ill look at motul.
    Castrol SRF Ordered! I am thinking of also doing SS lines and pads as well. Jon B?
    Quote Originally Posted by USAFPILOT View Post
    Yes...... they are a bit more $$ than Viper sets !
    We have SS lines for G5 Vipers
