Results 1 to 16 of 16
    Changing rotors to steel
    Hi
    I got recommended by a fellow ACR-e owner to replace the stock composite rotors with steel since they are so expensive to replace and will wear out pretty quick if you do serious track work. Is there anyone who did this and what is your experience?
    Any suggestion on brand of rotors and pads?
    FSTENUF's Avatar
    PAST RED LINE
    This is the best set up I have found. Total time to swap out the CCB'S to Steel is less then 1 hour.
    BELANGER HEADERS/HI-FL0W CATS / EXHAUST/TRACTIVE SUSPENSION AND ARROW TUNE
    Quote Originally Posted by eckeph View Post
    Hi
    4,000 hard track only miles on my ACR, front original rotors still going strong. And 3,000 hard track miles on my 9.0 track car, has the ACR brakes, never had to replace a rotor yet on that either.
    2013 caged 803whp 9.0 liter, 2016 ACR, 1996 GTS, 2001 RT/10, 2003 SRT/10, 2018 McLaren 720s, 2020 G63, 2005 Ford GT, 2019 Megacab Dually
    Quote Originally Posted by Arizona Vipers View Post
    Hum... that's interesting! I would love not having to change rotors and pads. There are enough other expensive mods needed
    Would be nice to hear if others have the same experience!
    1ststrike's Avatar
    WIsconsin
    Switched mine to steel. Up at Road America a 3 day event would use up a set of Carbon Ceramic front pads. With the steel rotors and pads can do at least double the events before replacing pads. $1400 to $300 in comparison on pad cost.
    Enthusiast USAFPILOT's Avatar
    Jul 2018
    Spring TX
    Those are the rear brakes right? ACRs are a 6 piston caliper in the front aren't they?
    Looks like rear, unless its AWD lol
    Quote Originally Posted by Marc_ View Post
    It's the rear. You can tell by the hand brake calipers
    Quote Originally Posted by 1ststrike View Post
    So, maybe I misunderstood my friend. Is it the pads that will wear out more quickly than steel? And the rotors will not?
    sharmut's Avatar
    Feb 2014
    @OP, it's the combination of both. Heat causes the carbon rotor disc to oxidize, exposing more of the fiber material, which then acts like a cheese grater against the pads. After blowing through a new front CCM pad in a single track day(five 20min sessions) I switch to the Girodisc/Raybestos(ST43) setup and not looked back.
    Enthusiast stradman's Avatar
    Quote Originally Posted by TKO MOTORSPORTS TEAM View Post
    We have never had any problems with the ACR carbon brake package, its almost bomb proof. Dozens of track and test days, full tank runs, sprints, endurance on multiple cars. Pro drivers, amateur drivers, track record here and there. ACR carbon brakes and pads we have never had a problem with brake temps or excessive pad wear and brake fade is almost non existent with proper service . BUT there are draw backs. Pads are expensive if your not accustomed to carbon brakes ( in the carbon brake world viper pads are a frickin bargain). Pads can be hard to find at times, only one pad compound available, caliper service life is cut in half.
    But with anything you always have to apply your " application" . If your looking for best bang for the buck, maximum amount of time on track keeping the good times going steel rotors are the way togo and adjust your driving style to a steel rotor brake package. If your trying to set lap records or in competition then stick with the carbon. No matter what brake package you go with you have to run heat shields on all the ball joints.
    What sort of heat shields are those you mention?
    TKOSROD1300K
    5TH GEN VIPER BALL JOINT HEAT SHIELDS 416.00
    Yes, those are on my list.
    Columbia River Gorge near Portland OR
    I am happy to report that PartsRack has over a dozen happy ACR-E owners who have switched to the steel setup in photos above. At our COMPETITIVE prices...... I wish I could translate screen names to customer names !!
    We have replacement rings and pads in stock to keep you on the track.
    NOTE: IF YOU DONT KEEP YOUR OE CC ROTOR HOLES CLEANED OUT, YOUR ROTORS WILL OVERHEAT AND FAIL PREMATURELY. YOU GOTTA DO THIS
    Quote Originally Posted by JonB ~ PartsRack View Post
    I didn't find any GiroDisc on your website?
    Yes, I did the rotors on my GT3 not long ago!
    John is correct here! Tom O'dell told me the same thing!
    jwalk's Avatar
    May 2014
    I switched to Girodisc also. Love them.
