Results 1 to 12 of 12
    GTS Manual Door Latch Relocate Mod Hack to clear Roll Bar Covering It
    You want to talk about panic?
    I was at the light at a major intersection on McCarren Blvd in Reno, when my Positive Post lost contact and my car is now electrically dead. It was at night, I'm in the fast lane, and I realize I can't reach the latch. FIRST THING WAS DISROBE since heat was going to be a factor. I'm topless and at 5'10 & 290 lbs, quite a sight. Somehow I contort my body to get at the latch and escape my entombment. Then Hood up, tighten stud and on my way - I swear people will tell the story about the topless, fat guy that had broke down!
    That latch is also virtually impossible to reach with the rear hatch up too.
    I need a solution.
    FIRST THOUGHT: A loose plastic tie that goes around the roll bar tube and also around the top of the pull tab. If I can keep it on the tab, it would be easy to grab the tie. However I think the tie would pop off the end of the pull tab. I could drill a small hole towards the tab end and secure this tie with a tiny tie or... you get the idea.
    What do the racers do? Any clean solutions out there?
    Have posted about this in past when friend and I got locked out of his 01 GTS with rollbar while doing IOD test.
    The solution was provided by Tom Sessions...in that the emergency latch can be bent around rollbar without breaking anything. In was skeptical...but it worked. Frankly I thought it would break the latch handle but Sessions was right...AGAIN !!
    "Bent around the roll bar" - don't see it. Lever is plastic and vertically aligned parallel to tube.
    In the situation that I described, the roll bar was on top of the latch...completely blocking access...hence the need to pull hard to get it past the bar. It worried me but it worked. Your situation looks different. Glad you could grab it !!
    I re-bent my roll bar to miss the catches.
    Big job
    https://www.flickr.com/photos/905823...h/34063856111/
    If you have the standard Autoform roll bar the other alternative is to shorten the plastic tab on the pillar. I elected for the harder route
    I'm going to look into this, but part of the problem is that you must "dig out" the latch first beforeyou can get a finger behind it. If it is possible to slide a straight finger under it (which is the only thing you can do with a roll bar over it) that may be a solution. NOTE: I think this would solve the operation through the open hatch back too.
    The lever can be moved enough to get my finger under it without engaging the door latch mechanism.
    So a solution may be some kind of bumper/spacer/etc. that keeps the lever sticking out all the time. Of course, now it will become a potential "harpoon" to potentially snag clothing during ingress/egress.
    You guys are talking about this part?
    All you have to do for a quickfix is trim the top of the tab off another thing you could do if you wanted is to drill a small hole in the upper part of the tab and put a material loop secured with a rivet, that way it would be easier to grab hold of and not cause any snagging issues.
    Thanks Fatboy 18 for the PICS and TIPS,
    In my case, the roll bar does not interfere with the operation of the latch - problem is getting fingers under latch.
    Since it is plastic,
    • I'm concerned about weakening it with a hole
    • It may embrittle with age which would become a real shit show if the tab breaks off! This is a CRITICAL part and should be made of metal.
    Has anyone ever crawled out the passenger door? maybe when storing car in a tight space? (Is it possible (!) )
    Other thoughts:
    • Mod a backup battery
    • Route another mechanical release in case of lever breakage or roll bar interference
    • Fab a metal mechanical latch lever which will never break
    • Buy a used driver's side window and carry an automatic center punch
    Found this gem:
    75 year old man Trapped 14 hours in Cadillac w/electric latches in Cleveland
    Yes, many of us have crawled into and out of the window of a Gen II Viper...which is what I have seen professional drivers do who make car deliveries from enclosed trailers. The same thing goes with real race cars with a full cage.
    Unfortunately, not all body builds can utilize this method.
    mine was cut with a dremel to clear the bar.
    This is what I had in mind. A small rivet with a thin washer on the back to spread the load and a tab something like this [ATTACH=CONFIG]41701[/ATTACH
    You could use any colour material you liked (match the body's colour or go red for safety
