Results 1 to 14 of 14
    Aug 2019
    Rear Tires Hitting Fender
    Hello,
    One of my 98 Vipers the rear tires are rubbing on fender if a hit a bump. I have 18" front & 19" rear.
    Bought the car this way and as far as I know there is no adjustment.
    Suggestions appreciated!
    Ray
    Aftermarket rims and tires? I would also bet that you have lowering springs on your shocks. Pictures? You could go back tot stock springs or SRT wheels and tires to help tuck them in a little more.
    As suggested, that happens on even the newer Vipers when you go to a larger wheel/tire combo and/or lower it. It'll eventually rub a hole through the liner.
    There's a price to be paid for everything, unfortunately.
    ACR-ISH's Avatar
    Northern CA
    Stock is 18/18 right?
    Northern CA VOA Operations Director ****** 2014 SRT Viper - Full APR Aero - BC Racing Coil Overs - Forgeline GA3R-6 - and the list goes on...
    @acr_ish and @fivehundrednorth (dot com) on IG
    post a pic. most likely what has already been mentioned.
    MH60M's Avatar
    Apr 2014
    Twin Cities
    Does it have wheel spacers? Pics would be super helpful. Using this site through your mobile device is much easier for uploads.
    2001 GTS Sap/Stripes
    "Death Waits in the Dark" -160th SOAR
    98 Viper is likely lowered somehow.... spring caps, eibachs, or even both.
    Maybe even too-wide rear wheel spacers? Rubbing INNER fender, or outer?
    The above would cause your intermittent issue, aside from leaking shocks... miles on car?
    You say ONE rear rubbing. Drivers side? ... has extra wear due to driver weight.
    {{Rear Tires Hitting Fender
    Hello,
    Ray}}
    Aug 2019
    Hello,
    I will take pictures with phone and see if I can figure out how to post them.
    Need to pull tires and see what shocks look like. I will post more info after work.
    Ray
    Quote Originally Posted by ACR-ISH View Post
    Nope, 17/17... 18 inch wheels were first introduced in MY 99.
    Aug 2019
    Sorry for late reply!
    Tried to upload pictures but not working.
    It seems I have about 1 1/2 inch clearance from fender to tire. Tires stick out past fender about 1/2 inch. It also looks like I have adjust to raise or lower shock.
    I plan on giving that a try after I get new radiator installed on my other 98 GTS.
    Thanks,
    Ray
    Martyb's Avatar
    Sounds like you have spacers or wheels with the wrong offset. My clearance is about an inch and a half as well, but my wheels don’t stick out past the fenders. Hopefully it’s just spacers that you can remove. Check to see if you have adjustable coilovers, that would be a bonus as well.
    98 GTS
    70 LS6 Chevelle
    2014 Ftype V8S
    Aug 2019
    Quote Originally Posted by Martyb View Post
    Thanks Marty,
    I do not have wheel spacer but it does have custom 2 piece wheels. I think the offset is in the wheels. I do have adjustable coilovers so hoping I can pick it up just a little.
    Ray
    Buy new wheels.
    Martyb's Avatar
    Quote Originally Posted by 99RT10 View Post
    Buy new wheels.
    I agree Mike, having the correct offset is the way to fix this.
    98 GTS
    70 LS6 Chevelle
    2014 Ftype V8S
