Results 1 to 17 of 17
    Enthusiast Hawk's Avatar
    Jun 2017
    Cape Cod
    Need help finding a part or part
    Hi guys. I’m looking to replace the exhaust tip filler trim that attaches to the rocker panel that covers the muffler. I currently have the silver one and would like to change them with a matte black. Is this a stock part of something that is either being powder coated by an individual or anodized aluminum? I have seen them on the later model cars
    I looked online and found the part numbers 5SR72AAAAA -but it does not give a color option
    Dennis
    2014 TA orange #55
    I think a lot of folks just use bbq grill paint to change the color
    I power coated mine.... but to be honest....just tape off and use high temp paint.
    2017 Dodge Viper ACR-E 1 of 1 Ceramic Blue ( A&C Performance H/C)
    Jan 2020
    Upstate NY
    Can anyone post a pic of the high temp matte black tips as I might be interested to try it.
    Thank you very much!!!
    Scott_in_fl's Avatar
    Dec 2016
    How is the trim piece attached to the rocker? From the back with screws, I assume? If so, then I would pull the sill, remove the trim and paint it that way as opposed to taping it off in place. Should come out much cleaner. Just IMO.
    Gen5snake's Avatar
    Feb 2019
    If you remove that aluminum/chromed looking trim ring piece (screws from back side), be careful. There has been many on here that had problems with snapping the heads of the screws off, leaving the threaded section in the trim piece. You may want to tape it off...or just leave it alone.
    Quote Originally Posted by Gen5snake View Post
    100% correct. No chance all 6 bolts survive removal. They seize in the hole.
    We have the black ones in stock with new screws
    Thawk97's Avatar
    Is that piece painted? Or can you use something like Never Dull on it to clean it up?
    ACR-ISH's Avatar
    Northern CA
    Quote Originally Posted by BJG32 View Post
    Just paint it high temp black for six bucks. It's a trim piece. Don't try to remove it. Bolts will break plus pulling rockers isn't exactly fun. K.I.S.S.: Keep It Simple Sir
    And as always, post pics!
    PS Don't forget to join and become a supporting member!
    Northern CA VOA Operations Director ****** 2014 SRT Viper - Full APR Aero - BC Racing Coil Overs - Forgeline GA3R-6 - and the list goes on...
    @acr_ish and @fivehundrednorth (dot com) on IG
    Jun 2017
    Cape Cod
    I just got these in from Prefix. The finish looks great thanks Scott it’s always a pleasure doing business with you. I will post a picture of them in a few weeks once I take it out of storage and install them
    2014 TA orange #55
    Quote Originally Posted by ACR-ISH View Post
    What would you recommend doing for the surface prep of a discolored piece??
    '14 White TA #23 Bone stock
    '15 Z06 M7 Not bone stock
    Quote Originally Posted by Oh Three Z View Post
    I would clean it with a liquid silver polish to remove the black stains (works well on my GTS). Then clean well with Alcohol. Then paint with high temp BBQ spray paint.
    Jun 2017
    Cape Cod
    For $150 of parts and hardware I’m not so sure I would use a can of BBQ spray on a car like this.
    2014 TA orange #55
    Jun 2017
    Cape Cod
    Update-pictures of bezel installed .BTW I was able to remove all 3 screws from each original bezel with a little penetration oil and going easy. If you were to reinstall the original ones you would need new screws
    2014 TA orange #55
    Enthusiast Hamrhead's Avatar
    Apr 2014
    eastern PA
    That does look better. Clean.
    I have to do something with mine. One of these days...
    2015 Viper GT
    NE Ohio
    I removed mine and painted them. The high temp exhaust paint did not like the factory paint, I had to take them down to the base. The short of it, go with Prefix, that is $ well spent
