Results 1 to 25 of 31
    Nov 2018
    RHODE ISLAND
    rpm tach signal
    im installing my INNOVATE 3851 boost and rpm tach. i was wondering where should i grab the signal wire. injector?
    On my Gen 4, I grabbed it off of a coil wire using an MSD 8918 Tach Signal GMR Pickup:
    https://driveviper.com/forums/thread...l=1#post296461
    This wouldn't be an option on a Gen 3 since they don't use the same coil near plug setup. A fuel injector wire should work though.
    Nov 2018
    RHODE ISLAND
    any wire on the injector? cylinder 9 should be fine?
    Back In Black's Avatar
    Quote Originally Posted by RI-Viper View Post
    Are you using the MSD GMR? I would stick with a coil wire. Follow the installation instructions and you should be fine. Any cylinder will work but #9 is closest to cockpit access points.
    2008 Viper ACR
    Not sure which wire does what on the fuel injectors, but the cylinder # shouldn't matter. If it doesn't work for one wire, try the other. If you have access to a wiring diagram, that would help eliminate the guess work.
    Quote Originally Posted by Back In Black View Post
    I think he's working with a Gen 3, so I'm not sure that would work for him.
    Coil wire will not work on a gen3 period.
    This will work.
    Nov 2018
    RHODE ISLAND
    i have a pectel ecu stand alone system. so i dont wanna mess with this ECU i think the injector wire its going to be
    04 Viper RSI 1500hp E85
    I would contact pectel as you may have a tach signal from the ecu.
    I just don’t like tapping into injector signals. Just me. Probably fine.
    LATAMUD's Avatar
    Tampa / Kuwait
    Quote Originally Posted by Ramtuff View Post
    This will work.
    Quick comment on the Viper truck and Viper car, the engine harnesses are very different, possibly the pinout for the truck ECUs are different too. I tried to save $100 a few years ago and get a truck engine harness and just "stretch" it so to speak to work in a car that needed a harness. I made it work but it wasn't worth the time I put into it.
    To obtain a ECU pinout wire to work in C101 C31, I find ECU pigtails on ebay for like $20-30, the wires separate easily.
    https://www.ebay.com/itm/03-Dodge-Du...IAAOSwFN9eIgxR
    Nov 2018
    RHODE ISLAND
    i got it off the injector wire. thanks for the replys
    Nov 2018
    RHODE ISLAND
    update i had to purchase the MSD Ignition 8918. i hope to hook up too the injector wire. since i cant get a coil signal. waiting on part should be here friday
    So I'm assuming you were tapping directly into the injector wire? Was it just not a good connection?
    Let us know if the MSD unit works.
    Nov 2018
    RHODE ISLAND
    the msd unit doesnt work on either injector wire
    Nov 2018
    RHODE ISLAND
    i tapped into the c31 wire off my pectel system and still no signal to shift light.
    Did you try the coil wire?
    Did you try something other than that vampire tap? Those things regularly make poor connections.
    Nov 2018
    RHODE ISLAND
    Quote Originally Posted by pokeyl View Post
    didnt think that was a option on a gen 3.
    Nov 2018
    RHODE ISLAND
    i ohm it out to make sure is make a good connection.
    I looked over the specs on your gauge, you just need to set it to one pulse per revolution. This is due to the waisted spark fires once each crank revolution. Try any of the 5 coil driver outputs should work. The coils have much higher amp draw then the injector driver.
    Nov 2018
    RHODE ISLAND
    i have the gauge setup like this
    Viper Specialty's Avatar
    Cape Coral, FL
    1. You cannot use an injector signal to reliably get any kind of RPM info. Injectors turn off at decel, go static open at high loads, and have a very tiny PW at low loads. You need either a Coil output, or, a Tach output from the Pectel ECU which it can be programmed to do.
    2. Using aftermarket "stuff" to do things that a Pectel controller can do directly, is an exercise in redundancy.
    3. Those quick taps will absolutely cost you your sanity, wiring harness, and engine.... eventually.
    Dan Lesser
    Viper Specialty Performance
    www.ViperSpecialty.com
    (716) 912-5336
    VOA Tech Team
    Quote Originally Posted by Viper Specialty View Post
    I didn't think about that...thanks for the insight.
    Nov 2018
    RHODE ISLAND
    do you know which wire i will need to tap into? either coil (coils under intake) or pectel system? thank you much
    Cape Coral, FL
    Any coil output from either coil block will do the job. I cannot tell you how your car is wired, you will have to trace it. Any of the connected IGN outputs from the Pectel will work just fine.
    Dan Lesser
    (716) 912-5336
    VOA Tech Team
