Results 1 to 8 of 8
    What is this I found under the driver seat
    Regional Treasurer
    SNKEBIT's Avatar
    Wisconsin
    I think it's an inertia switch for the airbag/safety system?
    Sublime Pearl ACRRRR
    M&M Performance
    SSGNRDZ_28's Avatar
    Brownsburg, IN
    Seat position sensor for the airbag system to sense when the seat is fully forward.
    Georgia
    gpbtt's Avatar
    Sep 2018
    Doug is correct. The Factory tends to do a not so good job of routing the wires under the seat and that part will pull out or the wires will pull out of the connector
    Quote Originally Posted by SSGNRDZ_28 View Post
    Ohh... ok, So I can just leave it lying on the floor under my new seat?
    EDIT: or is it an inductive sensor so I need to keep it away from metal?
    SSGNRDZ_28's Avatar
    Brownsburg, IN
    Quote Originally Posted by eckeph View Post
    Yes, when It senses steel that is indicating full forward position as installed from the factory.
    Doug
    Georgia
    gpbtt's Avatar
    Sep 2018
    No, there is a slot in the front of the right seat support that it goes into.
    QUOTE=eckeph;406866]Ohh... ok, So I can just leave it lying on the floor under my new seat?
    EDIT: or is it an inductive sensor so I need to keep it away from metal?[/QUOTE]
    Quote Originally Posted by gpbtt View Post
    Yes, but I have replaced the stock seat with a OMP one.
