This is my 3rd Viper, so have a lot of experience and patience. It's a 2008 coupe with 47,000 miles and I replaced a mechanically failing RR wheel hub in August. (The metal bearing seal cover had been worn through from the inside because the cage failed, so not only were some ball bearings free, but the metal cover rubbed on the inside of the knuckle and grease running out.) The repair went fine. Over the last few weeks, I have a similar rubbing, chafing, metal on metal (or like dense rubber) squeaking noise from the same area (right rear?) that is correlated to vehicle speed, not engine speed or driveshaft speed, but I can't find what's causing it.
I inspected all four brake calipers to make sure pads weren't rubbing. I see the 2-piece rotor hats sometimes catch the inner edge of the pads, so filed the pads.
I backed off both parking brakes and haven't used them. They are very far from rotor.
Lifted rear wheels, set on jack stands, started engine, and ran 1st through 4th gear at engine idle speed for quite some time - no noise.
OK, maybe noise was really from the front, so changed RF bearing, wasn't that. Could it be LF? I must be really deaf...
My previous Vipers had U-joints, so I've pushed and pulled on these CV joint shafts, and while they go in and out of the differential, there is no rotational slop.
I thought the RR replacement wheel hub was defective, so replaced it again, no change.
I can replace the LF bearing because I have one and replace the LR with the one I took off, but not optimistic.
Is there a similar noise from a half shaft that feels tight? Or from a differential side bearing or seal? There aren't any differential oil leaks, but another step is remove the belly pan and get a better look.
Any idea is appreciated.
