PSA - dont forget to retorque your belly pan bolts. Mines never been off.. but daily driving has loosened them all. 1 fell out and the other 19 were not even finger tight.. this is on a 2017 from the factory! The vibration must loosen them.. wow!
I use nordlock washers and locktite now. Mine were getting loose quickly after this happened once even after retorque.
thanks ill double check mine
2013 RaceYellow/Black GTS Laguna
2015 Mustang GT Premium Perf Pack
While cruising with 20 to 30 other Vipers ,I would see 1 or 2 cars with loose belly pans .
White Mamba ,![]()
Thanks for the heads up! Another thing to check is the mounting bolts for the seats..! One of mine was looser than I would prefer.
@Bowen_Racing
2013 GTS Blue Viper GTS
good reminder!
X-brace bolts can loosen as well. double check torque specs, but I'm thinking those are 18-20 ft lb?
Yes, ive had my xbrace loosen once or twice. Thats an easy oil change service checking item;adding belly pan bolts to the oil change items to do list.
Just for convenience, belly pans bolts to the frame are 18 ft-lbs. The four that attached main pan to rear pan are 35 in-lbs.
The x-brace is 15 ft-lbs.
I lost 3-4 bolts on my old 15 TA 2.0. Fortunately there was a tractor supply where I could buy some bolts. When I got home the dealer gave me new OEM ones as a customer courtesy. FCA must really like those bolts as they ain't cheap. Now I use blue Loctite on them.
DougShelby has stainless steel ones 10 for $20.
http://www.dougshelbyengineering.com/viper.html
Stop with all the "common sense"!da959c72-0d8e-4491-a2af-9595ef682ae5_1749094817768.gif
New York is scum thanks to Comrades Cuomo and De Blasio,
baby Billy P!
Has anyone mentioned that the belly pan's main purpose is to stiffen the frame?
