Page 1 of 4 123 ... LastLast
Results 1 to 25 of 88
    Picking up my first Viper the day after tomorow deposit sent SIGHT UNSEEN
    hey guys
    long time corvette owner getting my first viper in 2 days.
    I sent the deposit sight unseen, the car is apparently owned by an older guy who rarely drives it, im dealing with his son now.
    Car is a rebuilt status, repaired close to ten years ago
    30 000 miles or so
    2005 convertible
    Frist basic questions are what should the oil pressure be on idle when its hot?
    Do these engines make any signature type of clicks or knocks inherintly? In the corvette world some of the older Ls engines, and some of the newer ones, have alot of chatter when cold, are the viper engines the same?
    Il be going for a very nice test drive, listening closely , going through all the gears, buttons and checking the gauges for abnormalities.
    i can check paint work quite well so no worries there, just mechanically, anything in particular i should be looking for?
    Congrats.
    G3 Oil Pressure is very high, 80-90+ on cold start. Can be 50-60 while running / cruising.
    Pushrod V-10 mild vlave clatter when cold idle
    Rear-End Clunk common during roll-off especially backing up.
    Hot sills can frighten or even scorch bare legs!
    Shifting 1 - 4 is like Vettes. Tranny is virtually identical
    Check your tire date codes. 05 came with Run-Crap hockey pucks.
    Your TPMS are probably bad / dead
    Good Luck
    sonicbloo's Avatar
    Northern England
    Good info from JonB
    Also check leaks from oil cooler pipes
    Make sure windows go up/down with no noises
    Check fan motor works on all speeds
    The 3 things I listed are the only issues I've had in 6 years. All were DIY fixes costing a total of approx $500
    Glad to hear the clunks and rattles are 'normal' as mine has those!
    It’s like JonB was right in the cockpit of my car. To the “T”, haha.
    Congrats man. Enjoy the ride.
    Thanks alot guys appreciate it
    I'll listen for the rear end and any abnormal engine noises, windows and watch the oil temps
    How would I know if the fans are on ir not ? Can I hear it from the cockpit?
    Quote Originally Posted by 1Willy1 View Post
    It will cycle in your driveway on a warm day
    sonicbloo's Avatar
    Northern England
    Sorry, I meant the fan that works the heater / air con inside the car, my fan motor (blower motor?) siezed up due to water ingress
    My blower motor had to be fixed in my car before I would take delivery. I had a reputable mechanic fix it for $150.
    I’m not sure what caused it to malfunction but it was an easy fix.
    Thanks guys ..had the dealer check out the car
    It has a check engine light on, throwing O2 sensor codes for both sides , examination showed no cats , no 02 sensors and headers installed.
    The fan blower motor as me toned earlier is seized
    Wheel bearing and some bushings have play.
    One rear strut is leaking as is the two oil cooler lines
    Going to try and knock off a few grand for these repairs
    Anything I should be concerned with here?
    sonicbloo's Avatar
    Northern England
    Sounds like minor issues to me, so nothing too serious, but good haggling points for getting the price down
    On my car, the fan/blower motor seized a few weeks into ownership. When getting to the motor, remove the plastic cowl carefully as the ends near the doors break off. Check if the motor is actually seized (mine was rusted due to water getting in) it is likely you may need a new resistor too, as this goes pop at the same time. Part No's are 5093248AB and 5014212AA. I stopped future problems by creating a safe path using silicone sealer, for any water coming off the windshield, so it doesn’t end up in the motor.
    Oil cooler lines had to be replaced on mine, I got OEM replacements as the modified ones were on back order, and 6 years on they are still ok
    As I said earlier, these issues cost me less than $500 for the parts
    The hole where the motor sits above the passengers legs, water easily finds its way into this hole!
    Thanks sonic appreciate the detailed response alot of good info there
    Good news is I now own the car and driving it 22 hours back home after flying to pick it up.
    This is definitely a car that needs some loving care , but for the price I'm super happy to own it
    Thd engine runs like a swiss watch , gauges all where they shouid be, fires up cold immediately no hesitation.
    The main issue it has is the return spring on the shifter doesn't go back to neutral.
    I heard many have dealt with this, some have fixed it with springs or alignment , new fluid or anti venom mod. Also it struggles going into 6th gear , I have to go from 5th to neutral and then to 6th, hoping I dont need a rebuild but preparing fit the worst.
    I got $3000 more off the price for this issue , $18 000 total off the asking price.
    I did well considering how the process have skyrocketed here.
    Anyone have any luck repairing these shifters without a rebuild?
    Thanks alot guys, cant tell you how happy I am with this car so far !!
    The first thing to determine is whether it is an OEM shifter or aftermarket and which aftermarket it is. Replacing the shifter is a very common modification. It was easy to disassemble the aftermarket B&M shifter I had and change to a stronger spring. I do not know about the others.
    Thanks Jim
    Saw a few threads on that, it's definitely NOT a short shifter
    Ideally I'd like to get an MGW so I'll start looking for that and ask for stiffer springs hope that helps
    sonicbloo's Avatar
    Northern England
    We're still eagerly awaiting pictures Willy!!!!!
    Lol Sonic
    Just arrived home last night, today I plan to start my restoration
    I will document with PHOTOS
    I'm.a member of lexus, vette, jaguar and many other forums
    This is the only one with no option to upload photos , is it just me or is this how it is?
    Along the tool bar when posting, at the far end of it 3rd icon from the end is a picture frame. Click on that and then it gives you two options, "from computer" or URL. Choose computer (which can be laptop, Ipad or phone) "Choose File" Select picture and it will convert it with a code to post, then press Upload file. Then you should see [ATTACH=CONFIG] a number[/ATTACH]
    If you press go advanced you can see you post configured before actually posting it
    This pic just uploaded from my laptop for demo
    Thanks fatboy
    I had to log in a different way now I finally have the ability to upload
    Anyways just to update my car is a rebuilt and the paint was slightly orange peeled and overall the car needs alit of love
    I started wetsanding the panels with 1500, thrm 2000 then a 3 stage compound and polish , I will then ceramic coated whole car afterwards
    Car neededca thorough detailing and lots of little things
    Curious, my car came with two keys but only one fob
    If I lose the fob is it possible to still get in and out , and use the car? If so where is the door key lock ?
    sonicbloo's Avatar
    Northern England
    I'll send you a private message regarding getting into the car without a fob
    Thanks sonic
    Enthusiast labtec's Avatar
    Mar 2014
    Maryland
    To manually unlock with key, look under drivers door along the inset forward edge. There is a key lock to unlock the door. Because it is never used, when you find it try unlocking door and lubricate if required so it is functional should you ever need it.
    Appreciate that labtec, found it
    Now I'm not so worried if I ever lost my fob lol
    We have Fobs and Keys at www.ViperPartsRackAmerica.com.
    And MGW or IPS shifters too. at www.ViperPartsRack.com
    TIRES TOO, fresh and new
    Congrats,and Thanks
    Hi Jon
    You have mgw in stock ?
    Can I also get the strongest springs ?
    Pls pm me if they are actually in stock now thanks
    And sorry for all the questions guys, wondering how to check the Tpms pressures? I dont see any way to do it on the dash which is the whole point of having them lol
