Results 1 to 11 of 11
    Tire Size for Gen V Wheels on a Gen IV
    Hey guys, first post here, have a question I was hoping you guys could answer. I have a black 08 roadster lowered on KW coil overs. I recently bought some gen v five spoke Rattlers. Wonder what tire size and brand you’re recommend? Should I run a spacer in the rear? Thanks in advance for your help.
    Dec 2016
    Houston, Texas
    should be able to run stock G5 sizes with those. Continental recently has new viper size tires in OEM sizes
    2013 RaceYellow/Black GTS Laguna
    2015 Mustang GT Premium Perf Pack
    SA Heat's Avatar
    Jul 2014
    Bulverde, Texas
    Banned?
    2009 Viper Red ACR w/stripe delete & black/red interior (1 of 1)
    1997 b/w GTS....sold
    Capital Vipers (DC/DE/MD/VA)
    RobertP's Avatar
    Mar 2021
    Probably didn't read when registering. I've seen it a few times here recently. If he didn't use his proper information to register he would be banned.
    But to answer his question I have gen V rattlers on my gen III with 355/30 rears and 295/30 fronts. honestly I think I could get 295/35's on the front to fill some of the gap.
    2006 SRT-10 VIPER GTS BLUE PEARL. N/A build forged bottom end Greg Good top end and cam.
    Quote Originally Posted by RobertP View Post
    When I went from 285/35-18 to a 295/30-18 front tire, I definitely had to lower the front to take up the enormous wheel gap that was left.
    JGK95's Avatar
    Chicago
    Anyone run 305's up front on 18's? How'd you like it?
    LATAMUD's Avatar
    Tampa / Kuwait
    Quote Originally Posted by JGK95 View Post
    I did on a set of sidewinders, R888R 35 series. I was on stock non adjustable shocks and needed to raise the front a little to clear road hazzards, was scraping everywhere. No rubbing on the body. Coincidentally, I swapped in R888R 295 on 19's and now they rub a little on the hard turns.
    Enthusiast StrokerAce's Avatar
    Jun 2019
    Central Florida
    OP, I think some.folks run the 345 in other brands that though labeled smaller are just as wide as other 355's.
    When I went from 285/35-18 to a 295/30-19 front tire, I definitely had to lower the front to take up the enormous wheel gap that was left.
    Were they different brands? Those sizes are almost identical in diameter with the 295/30-19 being just a hair larger.
    2013 GTS
    2018 RAM 1500 4x4
    1999 Camaro SS
    Quote Originally Posted by StrokerAce View Post
    Wow...that was a major typo. I meant to write 295/30-18, so I essentially went from a 26" diameter tire to a 25" diameter tire. I've since edited my post to reflect the correct numbers.
    Good catch.
    Jun 2019
    Central Florida
    Good catch.
    I've been tire shopping so that popped out. Happens to the best of us. No worries bud.
    2013 GTS
    2018 RAM 1500 4x4
    1999 Camaro SS
    JGK95's Avatar
    Chicago
    Thank you for the input, Bart.
    I run R888R 295's up front and 345's in back. I'm usually good driving them to the track and during but I do run Moton's in all four corners that make my ride a lot of fun.
    Jay K.
