I bought my childhood dream car about a month ago, and as I've started to replace parts and fix things that are wrong/broken, I figured that I'd start a thread to help keep track of what I'm doing with the car and to share its journey.
April 27, 2021
I became the fourth owner of VIN #00800 at 57,300 miles (second owner bought it in Feb 2017 at 50,000 miles; third owner in May 2020 with 54,000 miles).
Unfortunately, that's a paint job... not a wrap - done by the second owner; attempting to make a Batmobile, apparently (had a 4GOTHAM plate, and put a Gotham City Motors sticker on the roll bar).
In the ad, I was told that the car had the following modifications:
- Autoform T/A carbon fiber rear spoiler
- Autoform Rollbar
- Roe Racing Triple Pass Aluminum Radiator w/ Hoses
- Roe Racing Air/Fuel Ratio Gauge (Turned out to be a VEC1)
- RSI dual fans/relay kit
- A larger oil cooler (I think this is wrong; I think the power steering cooler has been changed though)
- Billet aluminum power steering bracket and pulley kit
- 3-rib 10 quart oil pan with Roe oil baffle system
- Moroso oil catch can (VTA though)
- Sidewinder II wheels with Toyo R888 tires
- Wilwood BBK with two-piece slotted rotors
- Stainless steel braided brake lines
- Parking brake relocation kit
- Borla catback w/ cats removed and piping heat wrapped through sills
- Vented Sills
- Front and rear tow hooks
May 01, 2021
Fixing issues right off the bat. Driver's side door sag; a quick and simple fix. In the process I found that the door card was loose, so I replaced the screw that was missing from the bottom.
Shifter was feeling absolutely terrible and the eBrake was super weak, so I took the center console apart to attempt to correct what I could.
Found a B&M STS with all four mounting bolts loose - also is missing the dust boot to keep gunk out of its insides.
I went ahead and installed an IPSCO 3" shifter extension. With the bolts torqued and the extension added, shifting became much smoother, but not perfect. Going from fifth to fourth was still really hard - shifter doesn't want to return to center, and seems to fight going back to center from the 5-6-R positions.
I also found a controller box under the Driver's Seat. Turns out the "AFR Gauge" was a VEC1 controller.
And then finally, I cut out the sagging elastic band from the ebrake boot and replaced with a small black zip-tie. It's not elegant, but it works. lol
