Results 1 to 17 of 17
    Best Coilover Suspension for a Streetable Track car
    I'm looking for an upgrade that would make a good difference from my actual BC racing w/upgraded Swift springs (12/14kg rate)
    Should I look for a 3 or 4-way adjustable coilovers?
    I'm looking for something stiff but streetable. The actual 12kg/mm front and 14kg/mm spring rate I have is pretty much the max I can tolerate, unless better quality coilovers keeps the car (a bit) comfy.
    Up The River..[Columbia River Gorge near Portland OR]
    Repeat Thread? Asked and Answered?
    https://driveviper.com/forums/thread...493#post438493
    TKO MOTORSPORTS TEAM's Avatar
    Jul 2019
    Reno, NV
    Hello Aevus
    Really depends on what you want todo with your car and why you want or need to upgrade. If your a serious street/track junky then its worth the extra money and upgrade to custom built shocks for your application. If your just looking to have fun run of the mill less expensive stuff can get you by.
    You always want to keep it simple especially when it comes to shocks. Properly designed and engineered 2 way adjust shocks is all you really need.
    One thread is about chassis, that one is about suspension. Overwhelming, JonB?
    Quote Originally Posted by TKO MOTORSPORTS TEAM View Post
    Hello Aevus
    Thanks for the input.
    I get most of my suspension info on suspensionsecrets website and it seems that 3 or 4 way dampers MIGHT solve my problem (stiff race set-up but streetable)
    https://suspensionsecrets.co.uk/damper/
    If a damper is 3 way adjustable then it allows the rebound to be adjusted and the high speed bump and the low speed bump to be adjusted. A track car needs to be very stiff to prevent the body from rolling on corner entry as much as possible if it has the grippy tyres and aero to match the set up like in most single seater categories. However, when the car encounters a sudden bump such as a kerb or a pothole in the track, it can make the car lift up in the air and lift the tyre off the ground due to the set up being so stiff. This is bad for grip as the tyre is not able to generate any grip in the air. One way to combat the sudden jolts is to soften the suspension to account for kerbs, however this means that the cornering capabilities are limited due to the increased body roll and mass transfer during cornering. This is where a 3 way damper becomes essential.
    But I have zero experience with such highly adjustable dampers, it might be overkill for my use...
    The other solution may be adjustable sway bars, so I get a planted mid corner feel while having something ''soft'' on a straight line
    Jul 2019
    Reno, NV
    Lots of good info out there and lots of bad info out there. Its very hard to weed through whats good and bad.
    There are a couple rules of thumb in motorsports world in general and shock world specifically
    1. Keep it simple. Dont think at your level you need to add complexity to go faster. Most of the time complexity ( unless you can support it) = slower
    2. Most 4-8 way adjustable shocks are absolutely useless for amateur road racing. Yes they are cool, and having cool looking knobs to turn is bad ass; But unless you are a full time race engineer looking for 2-3 tenths every weekend 4-8 way adjust is a great way to mind-F yourself and loose time on track.
    3. You cant have the best of both worlds. There is no such thing as great street /track shock suspension set up. You can have a GOOD street/track car suspension setup.
    Yes sway bars!. We have been over things just like this in tko tips and track tweaks
    If you have the option adjusting sway bars is almost always our first goto when trying to fix certain problems.
    I had GT3 adjustable sway bars on the Porsche I just sold and loved it. Now, on my gen3 Viper I find the ACR (solid) bars I just installed a bit soft, especially rear. And not being able to adjust them makes it worst... But, hey, maybe there is a good reason not to make it too stiff! No traction control, lots of torque, etc... That's why I was now focusing on the suspension.
    Enthusiast FrgMstr's Avatar
    Lucas, Texas
    I replaced sway bars on my Gen IV and put MCS singles on the car and have been very happy with it for rallies, autoX, and track days. MCS are nicely adjustable too when wanting to load up the trunk for rallies and weekends out and about. Car still very drivable on a daily basis IMO. I have done sub-2m40s laps at CoTA with street tires on MCS and always felt confident in the corners. I am not a "track rat," just casual, so what do I know?
    As long as it is not yellow.
    Jul 2019
    Reno, NV
    Quote Originally Posted by Aevus View Post
    Yes your absolutely right. Cars like vipers a little more compliance ( softer) is not a bad thing. Helps with driver fatigue increases consistency and you will have alot more fun on the track and better comfort on street.
    You might try working with the BC coil overs you have to get a better idea of where you want to go and where you feel improvement is possible. Possible you may even find that what you have now works for you and there is another area that needs improvement that maybe a better bang for the buck.
    IMO, the best way to make your suspension work is to free up the swaybar, wishbone and shock pivot points with aftermarket bushings and/or monoballs. This will provide very accurate control feedback and minimize deflections. You will also be able to feel each adjustment in your shocks. I already did monoball lower wishbones and rear shock clevis adapters when I installed my EMI Penske triples. They have just come into an entirely new level of responsiveness with the addition of urethane upper bushings, the IPSCO greasable sway bar bushings and TKO end links.
    Having the proper baseline shock valving and springs for your vehicle and driving style is extremely important. If you are going to spend the money on them, spend time talking to their application experts so they are set up with the most flexibility around a design target.
    Quote Originally Posted by FrgMstr View Post
    Your car is beautiful, love the color match, congrats
    It makes sense. Will start with the TKO parts upgrade then I might get my rear dampers revalved with 16 or 18kg/mm springs.
    I prefer to make incremential upgrades, in order to understand better the effects of each.
    That being said, I'm still under the impression the chassis is (or will be, with all the upgrades done) the weakest link. I obviously shouldnt compare a Viper gen3 chassis with a carbon tub as I experienced with a Mclaren 720s, but still. A stiff chassis is something really enjoyable. Maybe I could start with an X brace over the engine similar as the gen5 ACR?
    I think that the Gen 3 cars - even with no fixed roof, were notably stiffer than the Gen 2 GTS in beaming and torsion. Published specs might show the numbers.
    IIRC, they had structural firewall castings made of magnesium. If you try to x-brace the front, you should investigate the Comp Coupe platform to see where/how they tied in; or if they are similar enough to copy or not.
    Dean, I'm curious: what spring rates do your run with your Penske triples?
    Few options for my gen3: BC racing, Moton, KW and Penske.
    So far I'm considering either BC racing singles w/Swift springs or Penske w/Hyperco springs.
    Swift are available only by 2kg increments (roughly 110lbs/in) which is not as convenient as the Hyperco (25lb/in ?)
    Would like 725-750lbs front and 925-950lbs rear (based on my experience with the BC racing I have now)
    Jul 2019
    Reno, NV
    If your choosing between Penske or BC.... Penske is a far better shock and spring package and a much better choice, BUT they arent cheap. Hyperco springs are the best springs available and the only springs we use. Penske shocks are one our competitors but we have to be honest and always respect well engineered products.
