Results 1 to 25 of 29
    Fluid change parts and tips Diff transmission oil brakes
    So it has come time to do a change of some of the fluids and while I have the car in the air I might as well change them all. I made a list below of parts I will need for each procedure. Please feel free to add anything you think I would need or any tips so I don’t F anything up. I will be using a rent by the hour garage so being prepared is the primary reason for this post. I’m sure the very moment I click post I will realize I forgot something on the list. Thanks.
    Oil- 11 quarts of 0w-40, Oil filter Mopar- Mo-041
    Brakes- 4 bottles DOT4 mopar fluid, turkey baster, motive pump, motive adapter, catch can with hose, brake cleaner
    Diff- 3 (500mL) bottles of Mercedes A001989520310 fluid (since it apparently has an easier dispense bottle)
    Transmission- 4 bottles Mopar 68218057AA, PTEF sealer, manual fluid transfer pump
    2016 Viper GT - Gunmetal Pearl
    Quote Originally Posted by AAA96 View Post
    I had not heard that before, so I looked and found that Mercedes just puts their sticker on a Castrol bottle.
    Yea I guess it’s the same stuff as what mopar sells and has the additive already premixed. The top of the bottle makes it easy to deliver the fluid into the diff. Can anyone confirm this?
    I've been using the Castrol stuff in mine (it has a Gen V diff) for 40k miles without the additive. No problems.
    You’re sure it doesn’t have the additive premixed? From what I’ve read it makes loud sounds and possibly leads to front wheel skipping when turning the wheels.
    I should have been more clear, I should have said "without having to add the additive". It has the limited slip additive already mixed in.
    Gotcha! So it’s exactly the picture you posted but without the Mercedes sticker.
    Make a video of the fluid(s) changes for us shade tree mechanics. I know it's not rocket science but would like to see a play by play.
    Quote Originally Posted by ViperJon View Post
    Funny you say that. I actually was thinking about doing videos last night while trying to sleep. Maybe I’ll drag my friend who can be a camera man with me to video me unbolting a few bolts and making a mess everywhere haha.
    Yes
    Central California
    Exhlr8n's Avatar
    You'll need something like this hand pump to transfer fluid into tranny and diff. Wont be filling directly from the bottle opening.
    https://www.amazon.com/Performance-T...07450123&psc=1
    Quote Originally Posted by Exhlr8n View Post
    Thanks, I had one of these laying around from a previous purchase.
    https://www.summitracing.com/parts/WMR-W1156
    And use the left drain plug for a more complete draining.
    https://driveviper.com/forums/thread...hlight=casting
    Possible or impossible to bleed brake system without taking wheels off or lifting the car?
    Take the wheels off...you might be able to reach the outer bleed screws, but you'll have a hard time reaching the inner bleed screws through the wheel.
    I've done it without taking the wheels off on a friend's 2016 Camaro SS, but that was only because the wheel lug key "disappeared".
    So while not impossible, it is not something I'd ever do again unless I absolutely had to - which was the case then. He was driving cross-country for a Navy deployment in the height of COVID restrictions and his fluid was giving him problems (because it was still the OE stuff). It came out pitch black.
    1997 Dodge Viper GTS || Matte Bentley Silver | 60k miles ||
    So I just got done with the brake fluid change. Took me one hour to do including cleanup and shower. I DID NOT take the wheels off and it was cake. RR, LR, RF, LF and outside then inside. I was able to connect the discharge hose and get to the bleeders fairly easily from the outside of the wheel for the outside valves. The inside rear valves I jacked the side of the car up and went from the inside. The front inside valves I just reached around the tire with the hood open obviously. Not sure if it was supposed to be this easy or if I messed something up haha. I took it for a test drive and seems fine, clutch and brakes work.
    Enthusiast chris_lee's Avatar
    Couple of quick tips that might save you a trip to the store. Speaking from experience lol.
    Differential: The differential top fill plug is a 3/8 hex socket. You will want to remove both rear diff drains plugs “base models without the cooler” due to the taps being different depths. Or just remove the one with the shortest tap “see photo” to get the full drain. The stock MOPAR fluid is what I would recommend on the Rear diff. Part number 68197927AA and it already has the limited slip additive. The label even says it’s designed specifically for the SRT vipers. I tried Royal Purple with the limited slip additive already in it and noticed a high pitch whine on decel. Others have used Royal Purple with no issues but that was my experience. I immediately drained it and replaced with the Mopar fluid, and it was silent. I was able to fill the rear diff just using a 3” plastic tube extension attached to the tip of the container nozzle.
    Transmission: You will also want to get a 1.5” 3/8 drive extension for the transmission drain plug. When you go to put that one back on your socket wrench may push up on this other bolt making it hard to feel how much torque you are putting on that drain plug. Any longer that 1.5” and you are hitting the frame on the other size.
    Don’t over torque the drain plugs. Clean up the factory thread sealant from the plugs. Use Permatex high temp thread sealant on all the plugs. Torque for the transmission plugs is only 25lbs and 20lbs for the rear Diff. Keep in mind that lubricated plugs with a torque wrench may go way past that before clicking. Using a standard size socket wrench with your hand closer to the socket should give you plenty of torque for those plugs.
    Apr 2021
    Great thread - I cannot find anywhere the size of the bottle Part number 68197927AA, looking for how many I would need to do a diff oil change.
    Enthusiast Hawk's Avatar
    Jun 2017
    Cape Cod
    I like the Mobil 1 for the rear axle(It has the friction modifier in it) , it takes 1.5 quarts. It is slightly easier if you pull off the rear passenger side wheel to pass the bottle into the axle filling hole area
    2014 TA orange #55
    Quote Originally Posted by Bootstrap View Post
    I also like that it mentions being specially formulated for our cars. Attachment 49086
    Apr 2021
    Awesome - many thanks!
    If you need more than 2 bottles of brake fluid to completely flush the system, you are doing things very, very wrong.
    what you guys are using for steering fluid??
