Results 1 to 9 of 9
    Trans drain and fill ports
    Anyone have a picture of the trans drain and fill ports (not the stock manual photo). If not, I am going to snap a few tomorrow when I do the fluid changes.
    2016 Viper GT - Gunmetal Pearl
    Georgia
    BSLSK's Avatar
    Bookmark this page. It's a great resource!
    http://www.billswebspace.com/viper.html
    Transmission fill/drain plug pic.
    http://billswebspace.com/viper206.jpg
    2014 GTS
    I took some when I did a clutch swap a few years back: https://driveviper.com/forums/thread...l=1#post373624
    I'm sure you could get better ones...mine were grabbed with my cell phone.
    Thanks gents. Will try and take some more just to have I case anyone needs them.
    Also, does the engine oil drain bolt use a gasket or thread sealer?
    Enthusiast chris_lee's Avatar
    Gasket for oil drain “gasket is part of the factory bolt”; thread sealer for the rest.
    Quote Originally Posted by AAA96 View Post
    Quote Originally Posted by chris_lee View Post
    Never got the gasket. Reuse or go get a new one?
    It is not a separate gasket - it is embedded in the drain plug. If you need to replace it, you replace the entire drain plug.
    Generally not needed unless you do something to damage the seal.
    Thanks Steve.
    jwalk's Avatar
    May 2014
    Make sure the oil filter rubber o ring comes off with the filter. Sometimes they stick to the engine block and need to be pulled off before re installing the new filter.
