Results 1 to 25 of 32
    Pulling off a stud Need expert advice
    Have to pull off several studs and I figured there would be no better group of individuals that were practiced in this art to ask for advice...
    Ok all jokes aside, decided to upgrade all my wheel studs to ARPs after snapping 2 front lugs last week, and having several more seize up as I went to remove the wheels yesterday - the only way these ones are coming off is by snapping.
    Just curious what tool you guys use push the original studs out of the hub?
    I've already got this Lisle 22800 on the way to help with the installing the new studs.
    https://www.amazon.com/gp/product/B000ETUD22/
    I just hammered out the previous 2, but I know that's abusive to the bearing - already got a new complete hub with bearing delivered to hold as a spare just incase I did some damage to it.
    Looking for a more refined way of going about this.
    2017 ACR-E
    2004 Lambo Murcielago -- Gated Manual, 2004 Challenge Stradale
    2018 991.2 GT3 -- Manual, 2019 Raptor
    Man that sucks dude!
    You need to remove the Brake caliper and get some cable ties and suspend it from the A arms, remove the disc so that you can get to the Hub. I would not recommend hitting them out with a hammer as the shock can transfer down into the hub knuckle and A arms which are the weak points on a Viper. Best way is to remove the wheel bearing from the Cast aluminium knuckle and press those out in a strong vice or hydraulic press. I use a couple of small strong walled sockets to place over the back of the wheel stud then using the vice tighten until the stud splines pop out of the hub. I have done it on my Gen 2 fitting the longer race wheel studs.
    Just to add to this... I removed the hubs and tried to use the cheap 6-ton shop press from Harbor Freight. It wasn't enough. I actually broke the press and returned it.
    As far as bracing, like Fatboy mentioned, you need something cylindrical and hollow in the middle (i.e. socket), and I found it needed to be a very specific size.
    '13 GTS
    Enthusiast Lawineer's Avatar
    Feb 2021
    DFW
    Holy crap, this looks like a whole lot of suck.
    2013 GTS- Black w/ Gunmetal stripes. DSC Tractive Coilovers, big wing, ACR sways, carbon stuff
    2014 BRZ: Race/track car. Full retarded &2011 Lexus GX460: Daily
    I have a very strong 6" jaw bench Vice, this is a couple of pics to give you the Idea.
    This was pressing a new one in
    You can tape a couple of hex nuts either side of the back of the stud and then place hub in the vice and squeeze it out You can also use a bit of heat on the hub and freeze spray on the stud to help squeeze it out but I don't mean heating the hub up red hot, just a gentle warm around the stud hole with a small propane torch. too much heat and you will melt the grease in the bearing.
    ViperTony's Avatar
    I used the Mopar stud tool mentioned in the service manual. Worked perfectly.
    Here are Doug Shelby's instructions for his titanium studs (I run these myself)
    https://cdn.shopify.com/s/files/1/04...f?v=1607363355
    Some localized heat might help
    13COBRA's Avatar
    Kansas City, MO
    Do you have an extra set you'd sell? I talked to Doug today and he has no intentions of making them again.
    Enthusiast darbgnik's Avatar
    Mar 2015
    Alberta Canada
    Looks like the tool J-45270 mentioned in Doug's instructions is just the clamp/press portion of most ball joint press tools.
    Seeing as how well my ball joint tool worked on old rusted parts, I'd be real confident doing lug studs with it, as long as it fit.
    Brad Williams
    2015 Competition Blue SRT - V/E DSC Suspension - TA1 Aero - StopTech's - SW2's with Corsas, Hummer H1, 70 Dodge Charger, BMW R1200GS Rallye, Ducati 999S, etc
    13COBRA's Avatar
    Kansas City, MO
    I probably will, but was looking for titanium to go with my titanium lug nuts.
    Try here
    https://www.mhtitanium.com/titanium-...RoCRmYQAvD_BwE Will most likely be a special order 1/2-20 thread and open wheel nuts, might want to see if folks are up for a group buy and get a better discount.
    Beware of titanium on titanium. The coefficient of friction can get very high for unlubricated joints making most of the installation torque go towards rotation instead of stretch.
    13COBRA's Avatar
    Kansas City, MO
    Quote Originally Posted by ViperSRT View Post
    Interesting. I would've assumed (wrongly I suppose) that titanium on titanium was safer than titanium on steel.
    Weather right or wrong, I always use a smear of copper slip grease on my wheel nuts.
    You can't beat a bit of Lube on your Nuts
    San Jose, CA
    Do you use titanium nuts as well? Prob a dumb question since I know you're all aout cutting weight. That reminds me, you did TI springs too right?
    As long as the applied torque is adjusted accordingly. The torque spec is intended to achieve adequate bolt stretch and clamp load with friction coefficients as intended. Adding lube to a intended dry application will increase the stretch and clamp load, and thus may cause premature failure of the bolt in tensile mode. A full analysis for torsional and tensile is required in order to determine if failure is imminent. As an engineer I would never recommend deviating from the specification unless you have knowledge of an engineered solution in the new situation. For instance a titanium stud would require a different (lower) applied torque to provide the appropriate stretch for titaniums mechanical properties (friction at assembly, modulus of elasticity and tensile strength) without failing. Here is a link to a quick comparison (note tensile strength may differ by specific metallurgy) https://www.thomasnet.com/articles/m...ties-and-uses/ Also note titanium dry friction coefficient can approach .8 or .9, which mean little of the applied torque will lead to clamp load. Not a good thing.
    Enthusiast Hawk's Avatar
    Jun 2017
    Cape Cod
    I used this tie rod end tool. I did need to file a little off each side of the jaw opening so the end of the stud would clear thru. Crank it tight with a wrench and if it doesn’t move give it a little tap(the nut end of the tool) with a hammer and crank down again. Remove the hub off the car and clamp the hub disk part in a vice to hold it still. To install the new stud put the stud in the hub, get a stack of washers and an open end nut and crank it on until it seats. It helps to hit it with a cordless impact gun to get the spline to engage into the hub before you put the wrench to it. Make sure you use a torque wrench on the lug nuts (107 ft/lbs.) do not use lube or antiseize if you use the full torque setting as the lubricant requires you to use a lighter torque setting. Jon B has better lug nuts that have a long neck and are a bigger nut size than the stock ones (13/16”). After the first drive check the torque again lots of times it seats the stud fully after a drive. Since I changed mine and always use a torque wrench I have never had a problem. I only bought an aftermarket ones to OEM specs( Dorman 610-395 Dorman Wheel Studs | Summit Racing ) . They are plenty strong if wheels are installed correctly ,by hand using a torque wrench ( unless you have a Prefix 9L and professionally track the car)
    OEMTOOLS 27276 Tie Rod End Remover (weselltools.com)
    http://www.viperpartsrack.com/viper-wheels/lug-nuts
    Caliper mounting bolts 85 ft/lbs.
    Hub to knuckle bolts 45 ft/lb.
    2014 TA orange #55
    Jun 2017
    Cape Cod
    2014 TA orange #55
    Quote Originally Posted by serpent View Post
    Yeah, all three. Still waiting to install the springs, had to get different sized seats since they are for an ACR shock and my car runs MSC.
    Quote Originally Posted by Hawk View Post
    Awesome! Everything I needed! If anyone is interested I can write up and document the process. Thanks again for the input all around.
    2017 ACR-E
    Yes, absolutely, write up and document. Always room for more info.
    Thank you sir
    Rocket's Avatar
    Phoenix, AZ
    First question - are you using a hand torque wrench and what torque are you setting to?
    2009 Vert/Coupe Rear End. Intake/Head/Exhaust. 705 crank/614 Wheels. Custom Red Drivers Stripe. ACR Splitter. KW Shocks. Plastidipped 6 spokes.
