Results 1 to 12 of 12
    10PISTNZ's Avatar
    Maple, Ontaio
    Anyone recognize this Vent
    Found this on the floor under my 01 GTS
    2001 RT/10 - Race Yellow
    2001 GTS - Red
    Yes its from the bottom of your starter motor
    10PISTNZ's Avatar
    Maple, Ontaio
    Thank you Fatboy. Not sure how I got knocked off. What is it’s purpose?
    Probably not a part I could find.
    2001 GTS - Red
    Looking for Mike's lost 747
    Moisture drain and pressure vent. From heat of expansion and condensate respectively.
    Quote Originally Posted by 10PISTNZ View Post
    Since it fell off in your garage, I would guess that the prime suspects are: cat, mouse, or squirrel.
    Quote Originally Posted by AZTVR View Post
    Solve any of those with a badass dog.
    Bill W's Avatar
    Aug 2018
    Greenville, SC
    If you want things to stay the same, things will have to change.
    2002 Red RT/10
    If the notch that holds it in the hole is not split, lube and gently work it back into its hole.
    I'd try a little ring of dish soap so it will dry and hold snug.
    10PISTNZ's Avatar
    Maple, Ontaio
    Thanks everyone. I think the notches on the plastic clips broke off. I’m going to stop into local starter rebuilding shop. It’s a Denso starter so I’m hoping this is a common replacement item
    2001 GTS - Red
    Enthusiast Viper GTS-R's Avatar
    Uxbridge
    They’re coming to get you Barbara.
