Results 1 to 11 of 11
    Aug 2021
    Exhaust leak advice
    Hi all,
    I have an ‘04 that has been with me for 11 years now so very familiar with it but I need some diagnostic help. A month or so ago started hearing an exhaust leak left side when cold, under load, then would stop when the car would get to temp . Now I hear the leak under load all the time. My guess is cracked manifold but wanted to hear any other ideas before I remove to inspect for cracks ( left side is not fun )?
    Ralph
    Is the exhaust all stock? I use plastic flex tubing (fish tank air line) to find leaks. Hazard!! A large leak can damage you hearing!!! I move the tube very slowly around the suspect area. When you get get close you will know. I have been using this approach for over 40 years and have never busted an ear.
    Sadly, cracks in stock Gen III exhaust manifolds have been reported frequently. May be time to go aftermarket.
    Aug 2021
    Will definitely try the hose idea, forgot that one. Hopefully I can hear it while idling. Has anyone had luck with welding the crack or are they mostly on the flange ? I was also going to replace the motor mount so thinking about removing the manifold. Decisions, decisions… lol
    Aug 2021
    Update !
    I had a couple hours and removed the exhaust manifold. As I removed the manifold the gasket fell apart ( see pics ) and I’m assuming that was my problem, I guess ? Adding a few other things like motor mount, spark plugs and thinking of having the valve covers painted.
    Thanks in advance,
    steve911's Avatar
    Cottage Grove, WISCONSIN
    Even though you may have found a possible source for the leak, keep LOOKING! That is not the traditional location where the manifolds leak. I would hate for you to put things back together and still have a problem.
    Steve A.
    2004 SRT10, 2019 Hellcat Charger, 2017 RAM 3500 Dually 4x4
    Quote Originally Posted by steve911 View Post
    Agreed...it is not uncommon for MLS gaskets to do that.
    You can see the leak second from the left. Good find. inspect the head and manifold for damage at that spot. Just use a straight edge to test.
    Aug 2021
    Sorry for the delayed response, we have an 11 month old running the house lol. Took a look again and can’t find a smoking gun on the heads other than an old oil leak from a faulty oil cap. I tried my best to take pics of the head. Also where are the manifold leaks most likely to come from? Was concerned of removing the heat shield and not being able to install it back.
    Quote Originally Posted by Ralph L View Post
    Header (or any) gaskets usually don't leak around the bolt, they usually leak half way between the bolts, unless that bolt was loose.
    Also, headers normally crack adjacent to a weld.
    Sure looks like second to left and last on the right were leaking.. loose manifold bolts maybe.
