Results 1 to 3 of 3
    2008 coupe rear suspension
    My friend just purchased a 2008 coupe. After going for a ride with him, the rear of this car seems to have a very hard or harsh ride. It feels like it has no rear springs at all. Does this car have adjustable shocks or is this normal for this model year? I would appreciate any suggestions.
    Regards,
    BUMBLE B
    There are too many variables to give you a definitive answer.
    Get the car high enough up in the air to get the wheel(s) off, and take some pictures of what's in there. Could be aftermarket, could be stock. If aftermarket, you're likely to see adjustable collars to raise and lower the spring perches.
    The OEM suspension on a non-ACR car shouldn't ride like you describe IMO. Mine was best described as bouncy, kinda like a pogo stick, but not harsh. It is also not adjustable, so you get what you get.
    If the car is an ACR (or has the ACR shocks/springs), I'd fully expect it to be harsh. That's due to the extra spring rate required to compensate for the downforce of the wing at speed. It is also adjustable (ride height, compression and rebound if I'm not mistaken).
    Bottom line: take some pictures, and post them up so we can see what he is working with. Could be a blown shock or two, or it could be poorly chosen aftermarket components (e.g. spring rates too high).
    LATAMUD's Avatar
    Tampa / Kuwait
    Someone installed lowering springs on my car before I owned it. They installed the front springs on the rear shocks, and the rear springs on the front. The front end was higher than the rear, the rear shocks felt like they would bottom out on hard bumps.
