Results 1 to 25 of 30
    Enthusiast johnnyk_6's Avatar
    Aug 2020
    Nebraska
    Gen III Caught on Fire - Possibly Catalytic Converter
    I was out doing some spirited driving with a buddy the other night when I noticed smoke coming from the driver's side wheel well at a stoplight. I quickly pulled off onto a service road where we hopped out to look for the source of the smoke. We didn't find anything obvious in the engine bay, but when my buddy looked under the car he saw a small fire that appeared to be near the catalytic converter on the driver side.
    I ran around the area frantically trying to find someone with water or a fire extinguisher while my buddy called the fire department. Fortunately, there happened to be a police officer nearby who had a fire extinguisher in his cruiser. The fire appeared to be in the hole near the front-driver-side jack point, so that's where I aimed the extinguisher and was able to put out the fire.
    I called a tow truck and had the car towed home, then jacked it up to try and locate the source of the fire. I found what appeared to be some kind of heat shielding around the exhaust/cat bracket that had melted:
    My guess is that the catalytic converter plugged up and started running hot enough to melt/ignite some nearby components. Does anybody have advice on how I could confirm that the catalytic converter is the cause? I haven't had the car towed to Woodhouse yet because I'm afraid I won't be able to find an OEM cat, so I'd ideally like to confirm that it's the cat and look around for the part myself before towing it and having the car sit in a lot for potentially weeks or month while I wait to find one.
    If it is in fact the catalytic converter, then this would indicate some other underlying problem that's causing my cats to fail. I had to replace a plugged cat last year within the first 3k miles of ownership (around 22k miles on the car when it failed). My theory is that the car came with a tune on it because it makes exhaust pops which I don't think are from a stock tune. I'm guessing a previous owner ran catless with a pop tune, then threw the cats back on before selling it, so I've been running a pop tune that smoked both of my cats.
    So I'm curious if I can check for signs of a bad cat myself before having the car towed to the shop and potentially waiting weeks for a replacement cat. I'd also like to know the best way to go about checking for a tune. Any insight or advice would be greatly appreciated!
    Martyb's Avatar
    It almost looks like copper wire inside the heat shield, never seen that. If the cat was clogged I would think you would have noticed as my bet would be it was running less than optimal. Just my 2 cents. Glad it didn’t burn!
    98 GTS
    70 LS6 Chevelle
    2014 ML63 AMG
    13COBRA's Avatar
    Kansas City, MO
    Just take it in. Even if it's a catalytic converter, just put high flows in, you'll be happy you did.
    johnnyk 6, put hi flow cats on. There are other places, local, so you don’t have to take it to Woodhouse. Mark Jorgensen, out at Bentley, doesn’t do that type of work, but there are other shops that can help. Extreme down on 132/L St can do it. I had mine done by them. I have a Gen 2.
    The Gen 3 guys can tell you if are any codes or whatever after install. I didn’t have any CELs.
    We don’t have emissions here or any inspections so you can make changes. Just keep the old exhaust just in case.
    Aug 2020
    Nebraska
    Quote Originally Posted by Martyb View Post
    When I previously had a plugged cat, the car had noticeable power loss and hesitation for several days and eventually threw a code. I didn't notice any performance decrease while driving before it caught fire so I wonder if it could be something else?
    Woodhouse will leave your car outside like the common Neon while waiting for parts. Extreme and others will pull your car inside.
    Aug 2020
    Nebraska
    This is definitely an option I am considering - maybe cheaper in the long run than replacing OEM cats.
    Quote Originally Posted by Viper98 View Post
    I will probably go with hi-flow cats if it turns out to be the stock catalytic converter. I will check out Extreme and look around for some hi-flow cats in the likely case I go with that option. Thanks for the recommendation!
    Aug 2020
    Nebraska
    That's exactly what I am afraid of. Don't want to tow it there and leave it outside for weeks, or have to tow it home again and back once the part comes in (Woodhouse is an hour away so a flatbed tow isn't cheap).
    13COBRA's Avatar
    Kansas City, MO
    If I were closer, I'd help out. My shop is 25 minutes NE of Kansas City.
    I suggest you purchase the hi-flow cats, once received make an appointment with the shop and have it towed once. Mike Moss, at Extreme, is an artist. He is very meticulous.
    Glad it's ok , could of been so much worse
    If it was my car id order two high flow cats and have a reputable exhaust shop weld them in same day
    Is there any reason we would need a viper specialist for a simple cat install ?
    Mbccenter's Avatar
    I purchased a gen 3 that had a cat fire. Car was running so rich on the one side that it put extra fuel in the cat. I figured I would just have to replace o2 sensor and be done. I was wrong. Took forever to figure out what was going on. Turned out to be a knock sensor. Computer can not read them on the gen 3 and they can do some crazy stuff to the tune. Funny thing was the car was pretty fast when it had the issue but slowed down once fixed.
    TT everything
    Viper Specialty's Avatar
    Cape Coral, FL
    Can you further explain what you found?
    We have pretty good access to G3 knock sensing parameters, and they have always served us well.
    However... one thing I have seen more than once is knock sensor wiring being zapped by old plug wires and damaging the PCM and/or knock inputs.
    Aug 2020
    Nebraska
    After taking the side sills off, it appears the heat shielding above the secondary cat burned through to the fiberglass layer.
    It looks like the rubber exhaust isolator piece is what caught on fire.
    So I'm fairly certain it's the secondary cat that failed. I guess it's time to look for some hi-flow cats
    Aug 2020
    Nebraska
    Quote Originally Posted by Mbccenter View Post
    How did you diagnose the knock sensor issue? Were there any other symptoms that could indicate this being the cause?
    Cats dont plug themselves.something Up-stream is fouling the cat
    Plugs, wires, coils, oxy sensors, and more, and now KNOCK sensors!?!
    Dont just replace the cats without finding and fixing the fouler or you are doomed to chapter-2
    ps we can offer HF, and OE used cats: JonB@PartsRack.com
    Thanks and good luck
    Aug 2020
    Nebraska
    ps we have HF, and OE used cats JonB@PartsRack.com Thanks and good luck
    I will take it to Woodhouse to see if they can't figure out what's plugging up the cats. Hoping it's just a pop tune that's dumping fuel into the cats. Regardless, I will be reaching out about some new HF cats. Thanks JonB!
    Oklahoma
    Scott Mannny's Avatar
    Harrah, Ok
    Jon B is the place to go, he'll have the parts to you QUICK!!! He has helped me so much, I don't go anywhere else.
    2010 ACR X #06, 03 Red SRT/10
    RT SERPENT's Avatar
    CANADA
    Quote Originally Posted by Scott Mannny View Post
    ... What he said
    00 RT, Black w/matte black , Roe 10lb charged, GG heads, cam, Borla, M&M, etc
    2017 ACR-E
    Used OE cats and rubber bracket in a UPS box, shipping tomorrow to get you driving....
    HF cats ship in 5-6 weeks.
    Thanks Manny and Serpent for the kind words.......
    RCR88's Avatar
    Apr 2016
    Carroll, Iowa
    Fred at the Blair store is great to deal with. Very knowledgeable.
    Aug 2020
    Nebraska
    JonB got me set up with some high-flow cats, and an OEM to tie me over until those ship. Thanks so much for your help JonB!
    Regional Technical Director
    Garron's Avatar
    Newmarket, Ontario
    Quote Originally Posted by johnnyk_6 View Post
    I repaired several Gen 3 cars that would repeatedly go through cats. It was almost always a cracked factory shorty header. There is an oxygen sensor in the header when the inside bracing cracks the oxygen sensor will read lean the computer dumps extra fuel until the cat plugs.
    This is very easy to smoke test through the exhaust pipe and check. Do not just install cats you will have the same problem in 1500 miles.
    On a lot of Ontario cars we would just install the full Belanger system because with the expense of the cats and manifolds you are almost at the same cost.
    Good luck
    You could have a bad injector on that bank uf this is the second converter on that side.. maybe running extreme rich. Could be washing cyl down also. Oil smell like fuel?
    Aug 2020
    Nebraska
    Quote Originally Posted by Garron View Post
    Good luck
    I will ask the shop to check for this - thanks a lot for the info.
    Oil doesn't seem to smell like fuel. The previous cat that failed was on the passenger side, so now cats have failed on both sides. Will ask the shop to check all injectors regardless. Thanks!
