Results 1 to 9 of 9
    Apr 2017
    Richmond Va.
    Gearbox fluid question
    I thought I was pretty well versed in cars but until I read it on this forum that I should ATF+4 fluid in my manual gearbox. Is there something special about ATF+4 that makes it great for the gearbox?
    New England
    daveg's Avatar
    Mass
    I used to run ATF+4 but switched to
    https://americanpowertrain.com/shop/...mission-fluid/
    96 GTS (# 33, Bone Stock), 66 Mustang Convertible, 66 Mustang Hardtop, 69 Corvette Roadster
    since 2020
    Ohio
    Steve M's Avatar
    Quote Originally Posted by Speedman View Post
    That was the OEM spec'd fluid for the '08-'10 TR-6060. It is relatively thin, but works quite well under most circumstances. The nice thing about it is that you can source it pretty much anywhere.
    For racing, some of us go with a thicker fluid, but that is really application specific. I use BG Synchro Shift II as per John Donato's recommendation - according to him, it has additional extreme pressure additives that helps keep things happy when you are banging gears hard.
    High Flow Cats | Gen 5 Intake Man. | UDP | HPT | 3.55s | MCS | DSS Axles | Nth Moto Clutch | 11.027 @ 130.06 (Vid), 1.78 60' (+1,622 ft DA, w/ 3.55s & Hoosier Drag Radials)
    Minnesota
    Back In Black's Avatar
    Motul Multi-ATF has always worked well for me.
    2008 Viper ACR
    2009 Viper SRT-10X | 190mph Standing Mile | 10.76@133.7mph 1/4 Mile
    since 2020
    Ohio
    Steve M's Avatar
    Quote Originally Posted by Back In Black View Post
    I've also used this in the past...no complaints with that fluid either.
    Happy Thanksgiving to All !!
    Now, a little history:
    Only 8 model years left the factory with something other than an "ATF" in the transmission...while 15 model years left the factory with an "ATF" of some sort. The early years came with Dexron II e, then Dexron III which ended with 1998. For 1999-2006, the transmissions were filled with Synthetic Manual Transmission Lubricant 75W-85 (a GL-4)...which was also used under a TSB ( issued in May of 1998 by my memory) for Neutral Gear Rattle on Viper years 1994-1998 where the customer complained of the NGR. Note that 1992 and 1993 were excluded from this particular fluid's usage...presumably due to potential seal issues. Chrysler allegedly furnished no official explanation to their techs or parts departments about this exclusion. Owner "Ron" tracked down some retired Borg Warner employees who offered the "seal explanation" on the old T-56's used in 1992-1993.
    Finally, model years 2008-2010 and 2013-2017 (which used the newer TR6060's) all came filled with MOPAR ATF+4.
    Make your own decisions...and be sure to read the fine print. AVOID using a GL-5 lubricant in the T-56 equipped Vipers...for fear of damage to the "yellow metals".
    VIPER BAZ UK's Avatar
    Royal England
    Cheers Steve
    My 09 ACR had an oil of some sort in it but now has the factory fill.. Guessing was the 75/85 castrol Syntec
    Support Tators Garage
    09 solid white HardCore ACR
    Baz
    Hi, Baz...agree that folks have used various fluid products based on everything from utilization of the Viper to availability of product...along with cost, "tradition", and of course successful marketing by the manufacturers.
    As someone here noted, I try to stay in the "safe" zone with our street-driven cars by sticking with OEM "factory fills". As you know. heavier use often dictates both more robust fluids and a more aggressive schedule of changes.
    Happy Holidays to you, your family, and to ALL of our Viper Friends in the UK !!
    Royal England
    Quote Originally Posted by Steve-Indy View Post
    Cheers Steve
    All makes sense as my ACR was used on track a little when it was home in the USA.. Totally agree for spirited street driving all OE oils..
    Hope you and the family had a great Thanksgiving
    Baz
