That is correct. Only two wires outside the harness. One for the backup camera trigger, if you install one. One one for the parking brake video lock out. My car had an aftermarket unit installed that already used this lead, so I just connected to it. There is a setting on the unit that I believe defeats the parking brake lockout, but because I already had the wire available….I cannot confirm.
I bought the XTRONS radio, OBD2 connector, and wireless carplay adaptor. Not compatible with factory Sirius or Nav, but either Google maps or Apple maps is better. It does change illumination color. It does work with factory amp (requires 4 wires to be swapped). It WAS great. Radio was slow to boot, OK. IMG_4660.jpgWireless carplay stopped working when USB dongle got hot. Carplay appeared to stay a little cooler if used "wired". Even when carplay overheated, it was still OK because i had a LOT of music on SD card. Clock was perfect size, great widget for home page.IMG_5656.jpg Icons could be arranged and removed. This allowed for convenient use of custom wallpaper. IMG_5655.jpgEasy to set custom boot screen. OBD2 worked GREAT with Torque app, canbus runs faster on Gen4 than Gen3 (my viper is 2010), so quicker response.IMG_4166.jpg
Then after 2 months, the radio's volume became "possesed". It would randomly auto-increase to full blast. Support SUCKED. They kept telling me to erase it, reinstall apps, check for ground, nothing fixed it. They procrastinate, give excuses, try to up-charge me, anything but exchange or refund unless I send it back to China for repair (minimum 2 month wait, ~$85 shipping). 8 months later, I bought a different brand, Awesafe. similar but homescreen and widget blows. Same story with carplay, OBD2 doesn't work, illumination does not change color. Still better than factory NAV radio with Sirius!IMG_5612.jpg
Drasch21, if you have more questions, DM me your number and I'll call you.
Confirmed. I disabled in settings. Also I didn't cross wires. I didn't want to cut and crimp. So instead I released them at the connector and swapped them there. Much cleaner.
DublinOH, did you spot check the accuracy on the TPMS readings. I thought their valve caps were Fugly, and I really like mine. My factory TPMS works fine and I check the pressure often. I also wondered how long the batteries last. Can you send a pic of how the valve caps look on your rims?
Cool, thanks for the clarification. I keep considering one of these or similar. I am always apprehensive about the longevity and having to tear the dash apart numerous times to correct issues or swap units.
Your post gives me some hope that it might be worth it.
Of course, then 70mopars reminds me of what I fear with this Chinese crap we are all stuck with these days.
At least it is good to know what they mostly work and cannot be worse than the factory POS head unit.
I have been looking at that exact same XTRONS setup. I definitely want the backup camera, maybe even front camera. The ODBII option is intriguing as well but I have a hard time believing it would work well, if at all. I heard a couple of stories of these cheap ODBII dongles blowing out factory ECUs. I am not sure how true that is.
I was a bit leery of that rudimentary TPMS cap deal. But, I guess if it works and is relatively accurate??
I'll take a close up of the wheel tomorrow. TPMS caps are a little on the large size, but not too distracting. TPMS appears to read about 1.5 psi high versus my digital tire gauge. Not really sure which one is off though. Hopefully I have better luck with regard to longevity.
I am actually surprised/impressed the TPMS is even close, sweet, that is close enough for me. Assuming they have a replaceable battery, it would have to be easier to replace them over the OEM entire sensors!
Are the wires that require modification labeled on the radio side plugs that you could reverse them there instead?
How in the world did you determine they needed to be reversed?
A photo of the wheel with the cap tpms sensor. I was worried I'd have to deal with the low tire light using these. So far, not the case. Evidently the factory system is reading the new sensors.
Dublin,
Are the wires that require modification/polarity switch labeled on the radio side plugs that you could reverse them there instead...or is that only possible on the factory harness.
How in the world did you determine they needed to be reversed? Did the amp just not function or was the bass response diminished?
Do it on the radio side, as I did. Do NOT cut into the factory harness. As far as figuring out what needed to happen, I take absolutely NO credit. Found the info on one of the facebook forums.
Agreed, That's what I would have done. I just wanted to make sure we are on the same page. Under no circumstances would I be cutting any factory wires. Worst case, I would have popped them out of the connector. I was hoping that was not necessary either and could be corrected up stream.
That's great info on the polarity!
THANKS!
Low tire / TPMS light came on last night while driving around. I expected this and was pleasantly surprised for a short while when the light did not immediately turn on. Oh well, anyone know if I can simply pull a bulb?
High Flow Cats | Gen 5 Intake Man. | UDP | HPT | 3.55s | MCS | DSS Axles | Nth Moto Clutch | 10.86 @ 130.66, 1.68 60' (+1,344 ft DA, w/ 3.55s & Hoosier Drag Radials)
I will also offer this: fixing your TPMS system would likely not be difficult, depending on what's going on.
If you simply have dead sensors (they only last ~10 years), but still have the original sensors, it would be a fairly easy fix, although you will have to find someone that can dismount/remount your tires. I can help with sourcing new sensors and programming them.
And whatever you do, do not throw away your original sensors under any circumstances...it can still be fixed if you do, but it will be much more difficult.
Bummer!
You might be further ahead to put a black sticker or tape over it for the time being. Then when you get new tires, swap them out.
Curiously, mine are from 2004 in the original tires/wheels and seem to be working. They were showing low pressure when the tires only had like ~15-20psi in them (when I took delivery). I filled them up to 29psi and the notification went off.
Maybe I have the world record for TMPS sensors! Either that or the entire system just said, I give up!
