Results 1 to 4 of 4
    since 2021
    Aug 2022
    Pittsburgh PA
    Gen 1 Dashboard Needs Cleaning
    The dashboard on my 1992 Dodge Viper has become sticky with age. As a result, it is extremely difficult to clean. Does anyone have any suggestions on how to clean the dashboard on a Gen 1 Viper?
    Welcome bubbapaul!
    Looks like you just joined. Congratulations!
    There have been many threads about this over the years. I can’t tell you where they are or even what headings. Maybe you found something already. I’m sure many will chime in.
    I have read guys have used:
    Simple Green
    Or
    Goof-off
    Or
    Super clean
    and there may be others.
    Be patient, my friend, your answers are on the way.
    Good luck.
    Got any pics?
    Gotta have pics
    Nov 2021
    Western PA
    I know some have plasti-dipped over it as well. It might not be a 100% perfect match, but is cheap and easy.
    since 2021
    Aug 2022
    Pittsburgh PA
    Dear Viper98,
    Thank you very much for the information you provided above. I took your advice and tried Simple Green. It worked perfectly in removing dirt and grime build-up without destroying the felt finish on the plastic dash board. I have heard of other people with Gen 1 Vipers that had similar problems with removing dirt from this difficult to clean area on the dashboard. It is difficult to clean because Dodge applied a felt layer over the plastic dashboard at the factory on Gen 1 Vipers. If you use too strong of a detergent, the felt layer gets stripped off. At that point, the only alternative is to paint the dashboard with Argent color, Matte Finish paint. Fortunately, I did not have to go this route.
    This was great advice and truly appreciated.
    BubbaPaul
