Results 1 to 25 of 39
Thread: 5th gear
    5th gear
    Hi guys,
    Having an issue with 5th gear on track. With high rpm it doesn't want to engage and instead wants to go into reverse! Which it obviously it doesn't so it kinda stays neutral.
    The car sat during summer time in storage. when I started it it didn't want to go into reverse sometimes!And driving on the road when shifting to 5th it wants to go to reverse!! Changed to Amsoil ATF fixed the issue and the tranny became very smooth.
    But today at the track 5th is not coaporating!! Not sure if anyone had this issue!
    2016 Viper ACR Extreme Prefix 9.0L
    Enthusiast ssmith71's Avatar
    Jun 2016
    Murphy
    Reverse lockout switch / solenoid not working?
    5th gear syncro's or clutch??
    Jun 2018
    Mandeville, LA
    I had the exact same thing happen to me in my 13. At mid to high RPMs in 4th, I could not get in 5th with ease. The shifter would just hit a wall and wouldn't go in 5th. I never forced it, but it just wouldn't go! Normal low/mid RPM street driving wasn't an issue, but on the road course, no 5th for me. I ended up pulling the trans to get rebuilt and bought a new clutch.
    The performance shop that performed the work said the only thing they saw issue with was the slave/throw out bearing was bad, clutch looked good. The transmission rebuild shop said they saw no issue with the 5th gear parts. Only wear on my 2nd and 3rd gear sets which I had to replace. I believe there have been a few posts in the past about this same issue and findings leaned towards throw out bearing/slave cylinder needing to be changed.
    Enthusiast Rare Snake's Avatar
    Winnipeg, Manitoba
    What track are you on to be hitting 5th gear? I'm jealous! My local little goat path gets me well into 4th on the front straight only.
    It would be so much fun to make that shift at full send without getting my car impounded! lol
    First it was a '95 RT/10, then came the '01 GTS. Now it's a '14 GTS. They say the third time's the charm, I have to agree.
    Nth Moto's Avatar
    Quote Originally Posted by theacr_viper View Post
    Hi guys,
    There are several things here that point to the clutch not releasing entirely, and subsequently causing damage to the synchronizer ring. The synchro ring for 5/6 gear is much smaller than 1/2 and 3/4 synchro's and will wear quicker showing the issue sooner.
    The reverse lockout solenoid is strong, but not as strong as a driver determined to get the car in 5th gear and you can push through it. This only happens when the driver is over compensating for the anticipation of it being a struggle to get into gear, typically.
    Enthusiast Hawk's Avatar
    Jun 2017
    Cape Cod
    Mine started doing the same thing at Watkins Glen. Ended up being my clutch was at the end of its life. I just picked up an Nth Moto clutch cant wait to try it out!
    2014 TA orange #55
    Thanks everyone for the reply!
    I just talked to the shop about the clutch alignment tool, and they said they used Audi's tool which looks to work but I'm 100% now sure the clutch is not aligned properly! It's a new clutch by the way.
    I'll take the trans out check the 5/6 synchros , check throw out bearing and possibly change the reverse lockout solenoid. I never forced it into 5th, I tried going easy into it with no luck!
    Rare Snake: It's Yas Marina GP first back straight easily 170/180mph with a fast car before you hit an 80 degree turn.
    Before you go too far, you might want to check to see that your shifter is securely bolted in place. Just a thought.
    Sure, thanks for the insight Steve
    Jun 2017
    Cape Cod
    Mopar 68029168AASOLENOID-Reverse LOCKOUT
    https://www.moparpartsgiant.com/part...8029168aa.html
    Reverse lockout discontinued WTF
    2014 TA orange #55
    I have had several Gen 5 track day cars with the same issue. On one car, the owner keep trying to push it in reverse at 130mph.
    Running a better clutch, isolating the clutch line from heat, properly purging the clutch hydraulic system of air (difficult on Gen 5's) all help.
    Using a proper gear lubricant, as opposed to ATF4 is pretty much mandatory on a track car.
    Once you do have an issue, you need to repair the transmission before doing any of the above.
    Just my experience, yours may differ.
    Enthusiast J TNT's Avatar
    Quote Originally Posted by Dan Cragin View Post
    Hi Dan , which gear lubricant do you recommend on the TR6060 ?
    Charter Member , SS OHIO, 9 Liter V-10
    BG Syncroshift 2
    Castrol Syntorque
    Rockland Gear T6060 Transzilla oil
    All have extreme pressure additives and work well at high tempretures.
    Or top plate
    If the clutch was not aligned the trans would not go in.
    Update ??
    Update ??
    Got the reveres lockout solenoid installed , drained the trans oil with little debris from reverse grinding. took it around the block and it seems fine for now. Reverse acting funny, sometimes it locks sometimes it doesn't I'm sure there is few teeth that is not there lol.
    I can't floor it and see how it acts with WOT in Dubai as there is speed cameras everywhere (it's not worth it) so I'll have to wait for a track day next week. But I'll update you guys!
    Thanks everyone for sharing their opinions!
    Jun 2017
    Cape Cod
    Where did you get the reverse lock out? The 6060 transmission is not exclusive to the viper I would think there’s others out there with a different part number? Is it the same as in the T-56?
    2014 TA orange #55
    I was lucky it was in stock in Dubai, part 68029168AA.
    Paid around 400$ though! Viper tax!
    Quote Originally Posted by Hawk View Post
    Jun 2017
    Cape Cod
    After looking around the internet I found out this part also fits challengers, Jeeps and other Mopar cars. Same part number retails for $200
    Some of the online companies have a reverse lock out that fits T56 and T6060 transmissions they however they do have them listed as a Viper part it does list them by transmission model. Hawks motorsports has them
    2014 TA orange #55
    Jun 2017
    Cape Cod
    https://www.hawksmotorsports.com/t5-...n-plug-dimple/
    They also make this magnetic drain plug for the 6060 transmission. Might be a good idea incase there are any fine metal partials in the fluid
    I just ordered one
    2014 TA orange #55
    Enthusiast stradman's Avatar
    Nov 2016
    London UK
    I had exact same problem a couple of years ago. Turns out the bushings on the shifter had gone. Got new shifter and problem sorted. No issues since then.
    Appreciate the insight Alex. Can I look at the shifter bushings from the inside of the car(boot cover) ? or must remove the transmission?
    Quote Originally Posted by stradman View Post
    These pics may clarify the questions. Important to note - not all bushings are equal (Delrin), there is some junk available. For clarification in pic 4, the oem install has the boot and boot plate held by rivets, I replaced the rivets with machine screws
    If you can remove the trans top plate, the extra inch makes the reinstall of the trans much easier. That was the main reason I replaced the rivets.
    The bushing is in the center of Pic#1. If anyone is interested, do a search, I have a complete write-up on the bushing replacement.
