In cold starts (25F and lower) the oil pressure runs up to 60 psi at idle but behaves somewhat like the oil is not returning to the pan quick enough. At higher than idle, the oil pressure may go up, down or stay the same. I verified this with a mechanical gauge (which indicated the dash gauge reads about 7 psi lower than actual.) It never goes low enough to worry about, but doesn't act normal.
I changed only the filter, no difference.
I added an extra quart, no difference.
I changed the oil from 5W-40 to 0W-40 to 5W-30, no difference.
I took the pan off and there is nothing floating to block the pickup screen.
I removed the oil filter adapter, inspected the oil cooler bypass valve and spring. They are fine.
I removed both oil pressure relief valves, replaced them with ones from a '97. (I bought a timing chain cover to see what I was getting into. The pressure relief valves in my car seemed to have more burrs, so I put the '97 ones in. All are tight.) Still no difference.
I made a hydraulic hose to bypass the cooler - so from filter out to engine in: oil pressure was 90 psi. Interesting, since the oil pressure gauge sending unit is on the return from the cooler, meaning the oil filter sees a lot more pressure than the gauge shows.
I removed the bypass hose, reinstalled the oil cooler hoses and oil pressure back to 65 psi. So the oil cooler (and the OEM oil lines) combine for a dramatic oil pressure drop.
Has anyone had a failed cooler or oil line - not a leak, but a blockage? Does a 25 psi drop seem correct (doesn't to me.)
It's a '98 GTS with 21K, bought this summer with 15K. I assume the car sat for long periods due to the age and low miles. Never had a hint of this when the weather was warm. Anybody have helpful comments or experience. No, not driving in the cold is not an option.
