Results 1 to 18 of 18
    2008-2010 torque specs
    Owners always asking:
    2008-2010
    FRONT SUSPENSION
    DESCRIPTION N·m Ft. Lbs. In. Lbs.
    ABS Tone Wheel Mounting Bolt 17 13 150
    Brake Caliper (Hydraulic) Mounting Bolts 115 85 —
    Hub And Bearing Mounting Bolts 61 45 —
    Lower Ball Joint Castle Nut 160 118 —
    Lower Control Arm Pivot Cam Bolts 102 75 —
    Lower Spring Seat Locking Screw - ACR Adjustable Shock 2 — 18
    Shock Assembly Mounting Bolts (Lower and Upper) 136 100 —
    Stabilizer Bar Bushing Retainer Bolts 68 50 —
    Stabilizer Link Control Arm Nut 23 17 200
    Stabilizer Link Stabilizer Bar Nut 23 17 200
    Tie Rod Knuckle Nut 75 55 —
    Tie Rod Adjuster Jam Nut 75 55 —
    Upper Ball Joint Castle Nut 102 75 —
    Upper Control Arm Frame Bolts 102 75 —
    Driveline
    Axle Hub Nut 257 190 -
    U-Joint Strap Bolts 38 28 -
    Differential Drain Plug 20 15 -
    Differential Fill Plug 20 15 -
    Differential Cover Bolts 47 35 -
    Pinion Nut 298 - 380 220 - 280 -
    Bearing Cap Bolts 88 65 -
    Ring Gear Bolts 122 - 150 90 - 110 -
    Frame Mounting Bolts 135 100 -
    Pinion Mounting Bolts 108 80 -
    BRAKES
    Adjustable Pedals Mounting Nuts 28 21 250
    Adjustable Pedals - Accelerator Mounting Nuts 12 — 105
    Brake Hose (To Caliper) Banjo Bolt 31 23 —
    Brake Tube Nuts 17 12 145
    Caliper Bleeder Screw 10 — 88
    Master Cylinder Mounting Nuts 28 21 250
    Parking Brake Cable Routing Clamp Bolts 10 — 90
    Parking Brake Caliper Mounting Bolt - Upper (Inner Hex Head) 32 24 —
    Parking Brake Caliper Mounting Bolt - Lower 52 38 —
    Parking Brake Lever Mounting Nut/Bolt 25 19 225
    Power Brake Booster Mounting Nuts 28 21 250
    Wheel Mounting (Lug) Nuts 135 100 —
    CLUTCH
    Clutch Bleed Screw 18 13 -
    Pressure Plate Bolts 75 55 -
    Clutch Release Bearing 20 15 -
    Flywheel Bolts 75 55
    COOLING
    Nut, Accessory Drive Belt Tensioner 41 30 -
    Bolts, A/C Condenser to Radiator 5 - 45
    Bolts, Coolant Pressure Bottle 5 - 40
    Bolts, Radiator Mounting 11 - 95
    Bolts, Thermostat Housing 11 - 95
    Bolts, Water Pump 11 - 95
    ENGINE
    A/C Compressor Mounting Bolts 23 17 -
    A/C Compressor Bracket Bolts 28 21 -
    A/C Line Support to Oil Pan 9 - 80
    Accessory Drive Idler Pulley 54 40 -
    Air Cleaner Cover Bolts 8 - 70
    Bell Housing Bolts 54 40 -
    Camshaft Position Sensor Bolt 9 - 80
    Camshaft Drive Plate Bolts
    Center Bolt - m10 65 48 -
    Outer Bolts - m6 12 - 106
    Camshaft Sprocket/Phaser Bolt 165 121 -
    Camshaft Thrust Plate Bolts 12 - 106
    Capacitor Bolt 9 - 80
    Coil Cover Bolts 10 - 89
    Connecting Rod Cap Bolts 45 + 45° 33 + 45° -
    Coolant Temperature Sensor 18 - 159
    Crankshaft Main Bearing Cap Bolts (Refer to 09 - Engine/Engine Block/CRANKSHAFT - Installation)
    Crankshaft Oil Scraper Nuts 28 13 -
    Crankshaft Position Sensor 9 - 80
    Crankshaft Position Sensor Heat Shield Nut 7 - 62
    Crankshaft Pulley Bolts 23 17 -
    Crankshaft Vibration Damper Bolt 339 250 -
    Cylinder Head Bolts (Refer to 09 - Engine/Cylinder Head - Installation)
    Cylinder Head Cover Bolts 11 - 95
    Cylinder Head Cover Baffle Bolts 6 - 45
    Engine Ground at Alternator Bolt 12 - 106
    Exhaust Manifold Bolts 29 21 -
    Exhaust Pipe V-Band Clamp 11 - 100
    Engine Mount to Block Bolts 61 45 -
    Engine Mount Insulator Nut 102 75 -
    Flywheel Bolts 75 55 -
    Fuel Rail Bolts 10 - 89
    Generator Mounting Bolts 47 35 -
    Ignition Coil Bolts 5 - 44
    Inspection Cover Bolts 9 - 80
    Intake Manifold Bolts 13 - 95
    Oil Cooler Mounting Bolts 5 - 44
    Oil Control Valve Bolts 9 - 80
    Oil Cooler Line Fittings 25 18 -
    Oil Pan Bolts
    Oil Pan to Rear Seal Adapter - M6 12 - 106
    Oil Pan to Block and Front Cover - M8 28 21 -
    Oil Pan Baffle Bolts 12 - 105
    Oil Pan Drain Plug 34 25 -
    Oil Pressure Relief Valve Cartridge 25 18 -
    Oil Pump Cover Bolts 12 - 105
    Oil Pump Swinging Pick-up Assembly 28 21 -
    Oil Pump Pick-up Pivot Bolt 14 - 124
    Oil Pump - Up Tube Bolts 28 21 -
    Oil Filter 18 13 -
    Oil Pressure Sensor 9 - 80
    Oil Temperature Sensor 18 - 160
    Up Stream Oxygen Sensors 68 50 -
    Power Steering Pump Mounting Bolts 28 21 -
    Crankshaft Rear Oil Seal Retainer Bolts 11 - 97
    Rocker Arm Bolts 32 24 -
    Spark Plugs 19 14 -
    Starter Mounting Bolts 54 40 -
    Thermostat Housing Bolts 8 - 70
    Throttle Body Bolts 11 - 95
    Timing Chain Cover Bolts 28 21 -
    Water Pump Mounting Bolts 11 - 95
    REAR SUSPENSION
    Hub And Bearing Mounting Bolts 149 110 —
    Hub Nut 325 240 —
    Lower Control Arm Frame Pivot (Cam) Bolts 102 75 —
    Parking Brake Caliper Mounting Bolt - Upper 32 24 —
    Shock Assembly Lower Mounting Bolt 136 100 —
    Shock Assembly Upper Mounting Bolt 136 100 —
    Stabilizer Bar Bushing Retainer Bolts 91 67 —
    Stabilizer Link Nuts 23 17 200
    Toe Link Adjuster Jam Nut 75 55 —
    Toe Link Inboard Mounting Bolt 75 55 —
    Toe Link Outboard Mounting Bolt Nut 75 55 —
    Toe Link Knuckle Nut 75 55 —
    Upper Control Arm Frame Pivot Bolts 102 75 —
    STEERING
    Cooler Mounting Screws 5 3 40
    Gear Mounting Bolts 203 150 —
    Hose Tube Nuts - At Cooler 15 11 130
    Hose Tube Nuts - All Others 28 21 250
    Pump Mounting Bolts 31 23 —
    Reservoir Mounting Screw 12 9 106
    STEERING COLUMN
    Driver Airbag Mounting Screws 12 — 105
    Intermediate Shaft Pinch Bolts 49 36 —
    Intermediate Shaft Extension Pinch Bolt 49 36 —
    Intermediate Shaft Extension Bearing Mounting Bolts 17 — 150
    Steering Column Mounting Nuts 17 — 150
    Steering Wheel Retaining Bolt 54 40 —
    TRANSMISSION
    Drain Plug 27 20 -
    Fill Plug 27 20 -
    Clutch Housing Bolts 34 25 -
    Clutch Release Bearing Bolts 12 9 -
    Shifter Assembly 20 15 -
    Top Cover Bolts 20 15 -
    Extension Housing Nuts 48 35 -
    Extension Housing Bolts 48 33 -
    Adapter Bolts 34 25 -
    * Side Shift Detent 40 30 -
    * Roller Detent Bolt 40 30 -
    Back Up Lamp Switch 34 25 -
    Skip Shift Solenoid 34 25 -
    Reverse Lockout Solenoid Bolt 18 13 -
    Guide Plate Bolts 22 16 -
    *Shift Lever Guide Bolts 27 20 -
    * Reverse Idler Bracket Bolts 30 22 -
    *Flywheel Bolts 74 55 -
    Transmission Crossmember Bolts 61 45 -
    Transmission Mount Bolts 41 30 -
    Top Four Transmission To Engine Bolts 41 30 -
    Bottom Two Transmission To Engine Bolts 68 50 -
    Transmission To Oil Pan Bolts 30 22 200
    Dust Shield Bolts 11 - 95
    *U-joint Clamp Bolts 38 28 -
    * Needs application of Mopar Lock AND Seal Adhesive or equivalent
    BODY
    Description N·m Ft. Lbs. In. Lbs.
    Convertible top center/3 bow bolts 5 — 45
    Convertible top center/4 bow bolts 6 — 55
    Convertible top cloth support panel screws 5 — 45
    Convertible top header assembly balance link shoulder bolts 20 15 —
    Convertible top header assembly rear rail bolts 18 13 —
    Convertible top latch screws 9 — 80
    Convertible top lower side arm linkage bolts 28 21 —
    Convertible top lower side arm linkage support bracket bolts 12 9 —
    Convertible top seal compression panel screws 5 — 45
    Convertible top tack strip nuts 12 9 —
    Decklid hinge bolts 28 21 —
    Decklid latch bolts 12 9 —
    Decklid latch striker bolts 12 9 —
    Decklid lock cylinder nut 12 9 —
    Door glass screws 4 — 35
    Door hinge bolts 37 27 —
    Door latch screws 12 9 —
    Door outside handle bolts 5 — 45
    Door window regulator nuts 12 9 —
    Fender support fasteners 17 13 —
    Fuel filler door screws 7 — 65
    Hood hinge to body bolts 28 21 —
    Hood hinge to hood bolts 12 9 —
    Hood latch nuts 12 9 —
    Instrument panel left mounting bracket bolt AND nut 28 21 —
    Instrument panel lower front mounting bolts 12 9 —
    Instrument panel mounting nuts 28 21 —
    Quarter panel door sill screws 6 — 55
    Quarter panel rear screws 6 — 55
    Quarter panel to fascia screws 6 — 55
    Quarter panel top screws 6 — 55
    Side view mirror nuts 7 — 65
    Trunk pan bolts - fuel pump cover area 9 — 80
    Trunk pan front support bracket nuts 12 9 —
    Trunk pan outside bolts 6 — 55
    Trunk pan trunk area bolts 28 21 —
    Trunk pan wheelhouse bracket bolts 6 — 55
    Windshield header AND a-pillar weatherstrip nuts 6 — 55
    Enthusiast St.Char's Avatar
    Westfield, IN
    That's awesome, I knows some specs cross over, but would love to have a spec sheet reference for a Gen 3
    Enthusiast DreadLox's Avatar
    State College, PA
    Good stuff, thanks for sharing Victxv10!
    Enthusiast A2008's Avatar
    Glass City Ohio
    Great Post ! We will all need this information sooner or later!
    I have all of this info as well as a maintenance tracking spreadsheet all done up in Excel...it won't let me upload the file, so if anyone is interested in it, just drop me a PM. Here are a couple screen captures to show what it looks like:
    This came in handy for me today, should be a sticky.
    2009 SSG ACR Hardcore 1 of 1 before it was cool
    2017 SSG ACR-eXtreme 1 of 1 after it was cool
    Used it again today. Bump to the top!
    Enthusiast slowhatch's Avatar
    Houston, TX
    Sticky this mofo!
    Great info guys.
    '13 SRT Viper GTS Blue Coupe | Prefix 9LX Stroker/Heads/Cam... ???whp | soon...
    [Previous] '08 VVO SRT-10 Coupe | Bolt ons... 605whp | 10.43@134mph
    [Previous] '06 Viper Red SRT-10 Coupe | Bolt ons... 460whp | 11.5@123mph
    Enthusiast G37Sam's Avatar
    Dubai
    This info is amazing!! If someone can post the Gen V torque stuff now that would be awesome!
    2014 Stryker Red GTS - Corsa Catback & Ceramic HFC's
    Enthusiast cashcorn's Avatar
    CA
    Yes, on the G5 as well. Getting ready to install the Stop Tec rotors on my SRT. I believe the same spec's though. thanks for posting
    Enthusiast rlhay2's Avatar
    Dec 2014
    Texas
    Another Gen V guy saying thanks!!
    2013 Viper SRT : ARH Headers : HP Tuners
    thanks for posting great info
    Toxic's Avatar
    Feb 2021
    Magnolia , TX
    Thanks for the post. Using this a lot. Sticky!
    2017 Dealer Edition ACR-E, 2014 Adonized Carbon Edition, ACR-X #16
    5 other past Vipers across the years
    JGK95's Avatar
    Chicago
    Hi Steve,
    Can I please get a copy of the spreadsheet at my email address?
    Jaygk95@gmail?
    Thank you,
    Jay K.
    JGK95's Avatar
    Chicago
    How about the fan shroud to the radiator?
    #18 in the diagram please?
    From 2009 Viper Sevice CD:
    Cooling fan retaining bolts...tighten to 10 N-m (89 in.lbs).
    Radiator mounting bolts...11 N.m (95 in-lbs).
    A/C Condenser to radiator bolts...5 N.m (45 in-lbs).
    JGK95's Avatar
    Chicago
    Thank you Steve!
