I installed a set of TA sway bars on my GTS to go along with my TA spec'd alignment and wholly shit did it make a difference. Any other owners looking to make their snake grab corners even better than it already does this is a quick, easy and inexpensive mod. The only special tool needed is a 3/4 inch ball joint remover to separate the stock bars from the end links. These are an exact fit, the only difference is TA sway bars are solid and weigh 17lbs each and GTS/GT/SRT sway bars are hollow and weigh 10lbs each.
Part Numbers
Front 5181444AA
Rear 5181438AA
