speaking of the gauge. Not sure how many of you actually are using it , but if you do, you may want to check accuracy.
I checked mine against 3 other gauges of which 2 were digital (if that matters) and found it to be 3 psi off on the high side.
i.e. at 30 psi, gauge was showing 33, i.e again 10% off.
I think most gauges fall within the 4-5%+/- accuracy.
With so many posts I’ve seen over the years with inquiries regarding tire pressure for street, track, strip, manufacture, etc, it’s obviously a concern even if 1-2 psi.
So, if you think you have 29 psi in your tires, you may only have 26-27 if using this gauge.
Other than that, it looks good (not sure if you’d need a gauge up to 160 psi?) and the hose length is good, storage pouch is nice too.
This post is for no other reason but for information, not a personal review.
If anyone knows a way to set/modify this for calibration purposes, please share.
-chip
