Home Forums The Track Performance Crankshaft
      back in the day.. before coloured tv and the internets …. contact Prefix … I think 522 cubes was about it for size….. .4.5 stroke needs a long rod and stubby piston.. then the problems start with ring stack .. land distance…rod ratio etc good luck
      Hi,
      I have a Gen I. Want to get a custom crankshaft. The crankshaft has been designed to have a 4.5″+ stroke, as well as 5,000 to 6,000 RPM – boosted – application.
      Any suggestions? For example – since the crankshaft is custom – I can go with a larger crankshaft snout to handle the supercharger. Would Mopar and big block snouts be adequate? Bladed crankshaft? Counterweights and counterbalanced?
      Thanks.
