Ok, Ill start off with my process of how I got here and then I’m gonna need help in what my next steps are. First off, I have a 97 GTS with approx 45k miles. Previously I think it had a super charger installed as there is a ROE VEC box and a injector impedance box on the car. After talking with Scott at ROE performance, he recommended I removed both those boxes. But I want to figure out this other issue before I create a new one.
I have had the “service engine” light pop on a couple of times. And it always produced the #2 cylinder misfire code. It always appeared in the most random of circumstances, never during anything obvious. I finally got around to getting the plugs changed. I originally went with some Autolite plugs, but the code came back. I talked to Viper Steve locally and decided to change to the OEM plugs, and check the ohms across the plug wires. The plug wires do look old, but the resistance across them was nothing to be alarmed. #2 wire was 100 ohms and #10 was 50. Fired it up and #2 was still dead. Verified with infrared gun.
At this time, I decided to swap injectors. So I swapped the #2 and #6. I turned the car over, but it stopped spinning abruptly. Thought to myself “what the hell did you do?”. I pulled all the plugs and tried to spin the motor over. Fuel shot out of the #6 cylinder and all over the inside hood and my work bench. (Verified #6 as I had my stepson stand over on the RH side with safety glasses on.) Apparently what stopped the motor from spinning was a hydro lock caused by fuel, not good.
I still was unable to tell if my injector was working on the #2 cylinder, so I reinstalled the spark plugs and disconnected the #6 injector. I got the car started and was able to verify the #2 cylinder was still dead.
So now on to my next step. First, I know I need to replace the injector O-rings (damaged on swap over). But what should I do about the next step in my process? I feel I will need to have the original #2 injector tested, as I’m thing it was stuck open. Then should I be looking at back testing the wiring harness, or could this all be caused from the VEC & impedance box?
