Home › Forums › Gen I / Gen II › 96/97 GTS fluids
Factory fills are:
Trans, Mopar #4874459 (4)
Diff,Mopar #4874469 (2) + additive Mopar #4318060AB (1)
Radiator, Mopar orange
Clutch/Brakes, DOT 4 fluid
Power steering, Mopar clear- not sure on the #I run Amsoil fluids
Trans,75W-90
Diff, 75W-140 + additive
Motul 600 for breaks,clutchHighly doubtful you’ll get a technical answer to why one fluid is superior to the others. I like Amsoil products and the quality is good/great (also cheaper).
Is anyone running a different weight motor oil in the car and what is that? I believe some of you FI heat monster are in the 15/50 product. Just curious?
Coloviper said:
Is anyone running a different weight motor oil in the car and what is that? I believe some of you FI heat monster are in the 15/50 product. Just curious?I’ve heard of people running rotella 15-40. That’s the same oil I run in my diesel trucks. I’m not sure if that’s for all vipers or built motor set ups.
I appreciate all the input. It may help others as well.
I’ve been all over and find conflicting answers and a mish mashes of recommendations for different applications. This is my question:
For an all original 1996 GTS with only 17,000 miles
What transmission fluid is best?
What clutch and break fluid?
Rear end fluid?
Radiator fluid if different than factory fill?
I know there are some seriously knowledgeable viper gurus out there. Please help!
