Home Forums Gen III / Gen IV ABS warning light on
    • SheViper
      When mine came on, it was a rear wheel speed sensor. And if I remember correctly, it was inexpensive and easy to replace.
      just get a abs capable scanner $75 for the scanner, $57 for the sensor through jonb, and 1 beers time worth of labor.
      Do you have a model/part number for the scanner tool? I understand you need a specific type to work with Dodge ABS.
      I have this one http://www.amazon.com/INNOVA-3100-Diagnostic-Battery-Vehicles/dp/B000EVWDAK/ref=sr_1_1?ie=UTF8&qid=1463403074&sr=8-1&keywords=innova+scanner
      Nothing special is required unless you want to perform special tests-module bleed etc, then you need the wi-tech or drbiii
    • mxmike27
      Thanks for the info everyone. I’ll order a scanner tonight.
      My ABS warning light came on a few weeks ago. I thought it might be caused by a bad rear wheel bearing as I had noticed lubricant on the inside of the wheel. I could also hear some bearing noise. So I swapped out the bearing with a new Timken. I was hoping the ABS light would have gone away but it didn’t.
      Is there some sort of reset that I have to do to get rid of the warning light? Or do you think I have some issue with my ABS?
      Thanks, Mike.
      – – – Updated – – –
      It’s an 09 Coupe. 38K miles.
