Home › Forums › Gen V › Alignment Spec after Tomball Caps?
Get the TA settings and start there.
Can someone post the TA specs?
Alignment specs for all models are in this PDF on page 3.
http://media.chrysler.com/dcxms/assets/specs/2014_SRT_ViperGTS_SP.pdf
I am running -2.5 front and -1.7 back on my Gen IV and love it.
I though as long as the alignment was good before the caps were installed, nothing would change?
cashcorn said:I though as long as the alignment was good before the caps were installed, nothing would change?
I know that mine did not need to be realigned after the install everything was still in spec.
3/4″ is quite a bit, the toe at least is going to change…
For those that have installed the Spring Caps on the GEN V are you changing the Alignment specs? My car might see 3-5 track days a year and would be curious if anyone is tweeking the alignment a little and what those specs might be?
