Home › Forums › Gen III / Gen IV › Anyone have a Gen 4 PCM laying around for sale or rent?
I have one but I’m not sure they can be swapped between VINs?
Check with viper specialty Dan lesser.. supporting sponsor
Doesn’t it need a number of starts before you can go for emissions?
No luck on insuring it as a collectible?
MTGTS said:
I'd lend you mine but it's not going to help with your emissions situation.Not sure if Dan is on this site as he's not on the sponsor list.
He’s a member, just not a sponsor.
Needs about 100 miles driving to reprogram before emissions. I have one, but don’t see parting with it for this same reason.
Rocket, check with Eddie Martin, I’d bet he’d have one at his shop or at home. You can also check and see if it needs to be vin specific like the venom controller. I’d also try and track the original from the seller.
MtnBiker said:
Needs about 100 miles driving to reprogram before emissions. I have one, but don't see parting with it for this same reason.You absolutely need to put some miles on the car after the swap. Also, you need to keep rpm’s up with the stock ecu in. I ran mine from Dan Cragin’s shop on the freeway in 4th gear for about 60 miles. Use 1 less gear and try to keep the RPM’s at 2k or higher.
Lastly, you’ll need to clear the codes when you swap. Good luck, Mike
Thanks in advance for the help. Need to get serious and pass emissions and am in need of a Gen 4 computer as I have the mopar PCM which will not pass emissions. Do not have my original PCM, headers, full 3″ exhaust with downstream O2 sensors zip tied along the trans tunnel.
Happy New Year!
